Toilet Leak?
  • Toilet Leak?
    I did a house about 2 years ago and got a call from the HO with a problem. He said he can hear water dripping when he flushes the toilet for a while and cant figure out why. He also said that the water in the bowl goes down on its own about 2 inches after 2 or so hours. He supplied the HD Kohler Cimmeron toilets. This house is piped in cast iron and has infloor heat by another contractor. My first thought is maybe a cracked or defective bowl and loosing water? Any thoughts or suggestions?
    Re: Toilet Leak?
    Sounds right to me. Somebody may have whooped an auger too hard.
      Re: Toilet Leak?
      Originally posted by Birddoggiest View Post
      He said he can hear water dripping when he flushes the toilet for a while and cant figure out why. He also said that the water in the TANK goes down on its own about 2 inches after 2 or so hours.
      Sounds like a leaky flush valve to me. Why it would only drop 2" is what's curious to me. Have them dump some food coloring in the tank when it's done filling and check the bowl in a half hour.
        Re: Toilet Leak?
        defiantly not the bowl. the tank should hold water,even if you remove it from the bowl. needs a new flapper
          Re: Toilet Leak?
          I wrote that wrong, He said the water goes down in the bowl. Sorry.
            Re: Toilet Leak?
            JC You are the MAN!
              Re: Toilet Leak?
              If we take the toilet being cracked in anyway out of the equation, then it sounds like a flush valve/flapper problem for the water noise.
              As far as the water level in the bowl dropping, it could be "momentum" from a near by drain is sucking the trap in the toilet.
                Re: Toilet Leak?
                It is on its own 3" stack that y's off another 3" that serves a toilet downstairs.
                  Re: Toilet Leak?
                  Just for the record, I want it clearly stated that it was NOT ME this time! I only do that in my own home
                    Re: Toilet Leak?
                    Gene, that's one heck of a service call! The toilet being in Idaho and you being in Maine... I've heard of plumbers who travel, but never actually met one before.
                      Re: Toilet Leak?
                      Have a clog in afghanistan?....well, I'm your man. For the right price I'll go to the moon and back.
                      I might have to arm wrestle Plumber Rick for the job, but according to Ben that shouldn't be much of a problem
                        Re: Toilet Leak?
                        I don't know, if Rick hefts that Propress around enough he might have arms like a chimp.
