Rehau
  • Rehau
    I have been using Rehau pex piping system for hot and cold water renewals since 2005 and have the old M-1 Rautool that pushes the brass sleeve over the pipe to seal it onto the fitting but it is a heavy and awkward tool to use so I just got a price on their new A-light battery tool which does the same thing as the M-1 tool but was quoted $2,550.00 and would like to know how much they are charging US customers.
    Tony
    Re: Rehau
    Last I heard in the U.S. Rehau was dead on the fitting department. They were going to abandon potable water connections. Only going to make pipe & steer toward radiant.
    All of the battery PEX and copper connection tools seem overpriced to me.
    But that does keep them out of the DIYers hands. For now.
    Have you seen the new Milwaukee M12 Uponor/Wirsbo expander? Most reasonably priced battery PEX tool yet. Might be time for a change.
    http://www.ohiopowertool.com/P-2964-...LAID=582960525
      Re: Rehau
      Have seen it and tried it. Much faster than the French made power tool.
        Re: Rehau
        Just picked my 12v up last week. It is way better than the French tool. Worth the 400.00, and cheaper than the Uponor gun.
          Re: Rehau
          I use Rehau pex and the copper crimp ring connection method. Works well and I've never had a joint leak. My supplier is still selling Rehau Pex,I picked some up yesterday.
            Re: Rehau
            I have Rehau in my Las Vegas home. A couple months ago the Developer sent a plumbing company out to replace all of the brass fittings due to problems with Dezincification. My understanding is it had to do with a deal Rehau and the Developer worked out to avoid a Class Action. While Rehau is still making the tubing, I believe Sioux Chief now owns the fitting portion of the system.
              Re: Rehau
              Souix Chief does indeed make the fittings now. I did the plant tour last June. Brass dezincification is the reason why Uponor has been telling its dealers to use plastic fittings whenever possible.
                Re: Rehau
                Rehau has been running around and changing over there expander heads before they drop all the brass fittings for plastic sometime this year which I read they were having trouble with in the US with fittings clogging up and bursting but haven`t head of in Australia fingers crossed.
                Tony
                  Re: Rehau
                  Go with Viega Pureflow and bronze fittings. No such problems. It pays to buy quality made products, and now made in the U.S. of A.!
                    Re: Rehau
                    Are the bronze fittings made in the USA? All my brass Viega fittings say made in China on them.
                      Re: Rehau
                      I won't even buy cheese from the FRENCH !
                        Re: Rehau
                        Then you will be glad to know Viega is German.
                          Re: Rehau
                          You have all been jumping on pex for being crap but with Rehau its not the Rehau pex but the brass yes the brass fittings now I am sure you will think up something
                          Tony
                            Re: Rehau
                            Tony
                            I don't know that the pipe has ever been much of a problem. It seems the weak link has always been the fittings.
                              Re: Rehau
                              Originally posted by toutahnow View Post
                              then you will be glad to know viega is german.
                              sorry, i still won't buy french cheese !!
