50 year old Cast Iron vs reciprocating saw
  • 50 year old Cast Iron vs reciprocating saw
    I have to cut into an existing 4" cast line to replace a cracked section. Not risking snap cutters, the line has hairline fractures already, and if they spread a good cozy job will turn into a never-ending nightmare. Angle grinder? Too much of a fire risk in an old place like this.
    So I'm thinking, reciprocating saw it is, with diamond blade.
    Just wanted some feedback/advice from the trenches before I went in there.
    Don't be shy.
    Re: 50 year old Cast Iron vs reciprocating saw
    I have used snap cutters on older CI pipe with no issues. But I did use a standard Metal blade on a Recip saw on areas where I could not get the snap cutters in. Cut through it like butter.
      I like to start with angle grinder and finish with sawzall with a Milwaulkie diamond blade.I use a spray bottle with diamond blade. Never had good luck with snap cutter.
      wookie
        I usually use the snap cutter to crush the bad CI above or below my cut, sometimes I get lucky and it makes a nice snap. Then use a regular metal cutting blade to make a clean cut. Or a channel Locks to snap off pieces, or a hammer! Tried the expensive blades for a while, they're just ok.
          I do this a lot on a AF base built in the 50's. The last one I did was a 4" drain. I used a new diamond blade I had bought and it went through it quick! Like a knife thru frozen butter. The only problem is that was the only blade I bought and it took all the words etc off. Don't have any idea where I bought it! I have since looked at all the different blades and decided it was hopefully a Bosch diamond blade. They are black which mine is, so I am hoping it is the same. That is my .02.
          God Bless You Super Good!!!
            If there are already hairline fractures, then the saw will surely aggravate the situation. I would suggest to replace as much of the line as possible.
              The lennox diamond blade for cast iron works awesome. Not like a hot knife through butter. but it gets the job done just fine. you will only get about 4 cuts with 1 blade and the last one I bought was 18.00 bucks. I won't show up to a job with cast without one just encase the snappers won't fit or it might crush.
                I prefer to use an angle grinder with a diamond blade. Just make sure to wear the proper ppe. In a close second it is a diamond blade in the sawzall. I just do not like the snappers.
                  get a Press Snap™ Soil Pipe Cutter
                  http://www.ridgid.com/Tools/Press-Sn...tter/index.htm
                    Ditto..I never like using snappers on old CI .If I do I do more rotating like cutting a piece of copper . If dealing with a real brittle piece of CI out comes the 4 1/2" angle grinder. Doesn't have to be a diamond blade . Have a couple regular cut off blades ready.Piece of cake ...
                      I will let you all know how it turns out, probably gonna be this time next week.
                      Thanks everyone for the $0.02
                        Well, the job is done. The cut took about 40 minutes with a diamond-encrusted blade in a Ridgid Fuego recip saw....great saw BTW. Blade lasted only one cut though, sacond cut required a new blade.
                          Jeez that is horrible. was it a lennox blade? last week a I was watching a buddy of mine cut with one and it seemed to take longer than I thought it should but he was using a battery powered ridgid reciprocating saw I thought that was the problem. About 2 months ago I used one in a bad spot. I had to make 2 cuts over head and it went O.K. better than 40 minutes.
                            the blade was a milwaukee....funny thing, though, I had to make another cut the next day. My wholesaler was out of diamond blades so I tried carbide-encrusted. Worked just as good, but the carbide didn't wear off like the diamond did.
