Do you have w.h. Anode guilt ?????
  • Do you have w.h. Anode guilt ?????
    Never check them Myself. Will start with mine. Have a great little book on W.H. " The water heater workbook By Larry and Suzanne
    Weingarten. Had it for years,and just started reading it again. I guarantee You will learn a LOT more than You know now. I always write on new W.T. install dates, and pick the nearest Holiday to flush each Year 5 Min. on tank, with magic marker. I wonder If My micro sea snake would do a good anode and sediment inspection ?
    Re: Do you have w.h. Anode guilt ?????
    YES! it does a great job of inspecting anode rods. I poke mine in through the relief valve opening. While I have that out I usually sell a new relief valve. The hot water hasn't damaged my imaging head yet.
      Thats It!!!! W.H. Anode Guilt!!!! Geez, the money I'll now save on therapists and Prozac. You the Man!!!
        tool unless you have a very good impact wrench or torque multiplier, good luck unscrewing an anode rod
          Don't understand this. I've taken out many with a socket and ratchet.
            P.S. Why even have an anode? (I know about sacrificial blah, blah, blah....)
            Most agree that tanks are designed not to last as long. So we've got tanks that used to last 20 lasting 10 with an anode.
            Spray that VooDoo patented enamel or glass lining on thicker & get rid of the anode altogether. In short, make the tanks like they used too & get rid of the anode. They'll get the same turnover without the anode fuss.
