6" pvc
  • 6" pvc
    Anyone have any tricks for gluing 6" PVC ??? Specialty tool??
    Re: 6" pvc
    Heavy body glue makes a big difference.
      Re: 6" pvc
      A 1/2 ton come along and straps, pull it together nice and easy. I like the gray Hercules glue for bigger pipe, and at least 12 hours dry time if your gonna run pressure through it.
        Re: 6" pvc
        Bevel the end of the pipe so it won't push out the cement.
          Re: 6" pvc
          thanks for the suggestions, I'm doing a bunch of 6" roof drain piping, had a hard time with the first 3 joints.
            Re: 6" pvc
            Does it bind going in with just one come along pulling it?
              Re: 6" pvc
              I wonder if you got a bad batch of something.
              Done hundreds of cuts/joints on a local college project.Not a single problem with assembling entire building main trunklines.No cumalongs,just hands.
              out of thousands of sockets 6,4,3,2 no leaks.
              Some start having problems cause something is out of alignment and they're trying to tweek after they set the joint.
                Re: 6" pvc
                i had a job that i was doing 6" sec 80 pvc and i used 2 riser claps to help pull it together then i had a strap that i tied around them to hold until the glue sets
                also use lots of glue
                http://www.google.com/images?hl=&q=r...iw=960&bih=466
                  Re: 6" pvc
                  one of these is helpful.
                    Re: 6" pvc
                    Ditto. Not as much though. You don't get much of a turn on the fitting though. Keep it wet.
                    They do make a bigazz dauber if you need it.
                    EDIT: I think stokefire might have a picture of one. Hard to see on my end.
                      Re: 6" pvc
                      Get the gallon can of glue and the big azz dauber, use lots of glue and pull it right together, I had to play with 10" sched 80 the other day, what fun
                        Re: 6" pvc
                        I took a couple of 6" clevis hangers and welded a piece of square stock on each side, took another clevis with a piece of square stock in the middle of the bolt, clamp the clevis on the pipe or fittings and pull it in slick as can be with the come along. One man set up 28' in the air in a sisor lift. Also made a jig to pull on fittings. I will try to post some pics u could fab these for any size pipe very easily. I dont think I had bad batch of anything, I just couldn't hold the fitting from pushing back out.
