Question
    Re: Question
    Diameter squared X .785 X Height x 7.48 = cubic feet of water.
      Re: Question
      Diameter squared X .785 X Height x 7.49 = cubic feet of water.
      Maybe I'm not thinking through it right. But as it is in my mind, there is no circle anymore. So there is no diameter, circumference, or radius. Unless there is a divisible somewhere in there.
      No?
        Re: Question
        No?
        To solve the problem you have to define the whole space (volume of the cylinder then work backwards from that as the equation does)... So yes you still need Radius ect...
          Re: Question
          Here is the math for it JC...
          Partial volume of Cylinder is: V= L*(R1^2 * acos((R1-h)/R1) - (R1-h)*(2*R1*h-h^2)^.5
          What does this designate in the formula Bill? ^
          Thanks.
            Re: Question
            Ah, he!!. Now I've got to find the calculator with the sine, cosine, etc...
              Re: Question
              No?
              I missed that it was on it's side.
                Re: Question
                JC here is a link that shows the math
                http://www.arachnoid.com/TankCalc/
                • #23
                  Re: Question
                  Pie R squared times height gives you a volume in cubic inches then divide that answer by 231 (cubic inches in a gallon) for the number of gallons...
                  Disclaimer: I do not consider myself a Ridgid tools consultant
                  Okie, Pi x radius squared gives the area of the circle. To get volume we also need a depth, or height. The third dimension.
                  I learned how to solve JC's question in high school, but darn it if I can remember that now. I'm grazing through http://www.khanacademy.org
                  It's in here somewhere, but there are so many distractions.
                  • #24
                    Re: Question
                    http://www.aqua-calc.com/calculate/v...ontal-cylinder
                    the formula
                    http://mathforum.org/library/drmath/view/54105.html
                    • #25
                      Re: Question
                      Errrm Geno Read the word right after "times" in my first solution
                      Put the Knob Creek away
                      • #26
                        Re: Question
                        You still need to find the area which may require using the formula for an arc and factor in the degree. Either way it is beyond my pay grade.
                        • #27
                          Re: Question
                          Imagine a 50 gallon round tank on it's side. You have access at the top to measure the amount of liquid inside with a stick. You can obviously measure the depth and calculate when you have 25 gallons i.e. half full.
                          But how much is left in the tank if it's below the halfway point say...half of that?
                          Not sure of dimensions. How 'bout 32"x22".
                          Thanks.
                          (Heard this on the radio. Can't remember how to get to the answer. )
                          Why not dump the water out into 5 gallon buckets and get a direct measurement?
                          • #28
                            Re: Question
                            Seems so simple. But it's not is it?
                            • #29
                              Re: Question
                              The second link gives a good description and explanation. I like how the doc states from the beginning that "The problem is not difficult."
                              Not for some.
                              • #30
                                Re: Question
                                Can't the glass is stuck to my hand. (Gravy still on fingers from Thanksgiving)
