Question
  • Question
    Imagine a 50 gallon round tank on it's side. You have access at the top to measure the amount of liquid inside with a stick. You can obviously measure the depth and calculate when you have 25 gallons i.e. half full.
    But how much is left in the tank if it's below the halfway point say...half of that?
    Not sure of dimensions. How 'bout 32"x22".
    Thanks.
    (Heard this on the radio. Can't remember how to get to the answer. )
    Re: Question
    I cannot answer that question because I'm not smart enough.
    Feel free to use that as your new signature line.
      Re: Question
      Pie R squared times height gives you a volume in cubic inches then divide that answer by 231 (cubic inches in a gallon) for the number of gallons...
      Disclaimer: I do not consider myself a Ridgid tools consultant
        Re: Question
        is anything going to happen for me if I would google "measuring volume of partially full horizontal cylinder"
        Diesel tank?
          Re: Question
          But you are no longer dealing with the cylinders volume. There is no radius anymore.
          Help me Bill.
            Re: Question
            Diesel tank?
            You might have a seizure and begin tasting carpet.
              Re: Question
              Obviously less than 12.5 gallons. 10.29488 gallons to be exact, assuming the 22" dimension is your tank diameter. Not sure the exact math invoived, but here is a helpful link
              http://www.handymath.com/cgi-bin/circlevali25.cgi
                Re: Question
                Diesel tank?
                If ya wanna do some cool math all ya gotta do is tilt the cylinder... now how do ya solve it
                  Re: Question
                  Originally posted by Devine Plumbing View Post
                  Obviously less than 12.5 gallons. 10.61660 gallons to be exact, assuming the 22" dimension is your tank diameter. Not sure the exact math invoived, but here is a helpful link
                  That's a blank page for me.
                    Re: Question
                    opps helps to read the question...lol
                      Re: Question
                      http://www.handymath.com/calculators.html
                      That link should get you there. Then just click on the calculator for a horizontal cylinder
                        Re: Question
                        I would never even attempt the first solution unless absolutely necessary.
                        I'm starting to feel a little retarded again
                          Re: Question
                          I got 10.29488. But I did cheat with a website. Can anyone show the long math?
                          Thanks.
                            Re: Question
                            Here is the math for it JC...
                            Partial volume of Cylinder is: V= L*(R1^2 * acos((R1-h)/R1) - (R1-h)*(2*R1*h-h^2)^.5
                              Re: Question
