some hack work for your enjoyment
  • some hack work for your enjoyment
    This commercial building was flooded back in 2008 ( like 9 sq. miles flooded downtown that year).
    This owner bought the building 2 months before the flood.
    Hired general contractor to do repair work a year ago, he and partner were almost done when they split partnership, so they couldn't finish.
    she called city to find out what she needed for inspections to get final.
    they had pulled building permit, but no plumbing permit ( not sure on heating or electric permits, but I doubt it).
    Plumbing inspector walked building with her and said to call a licensed plumber, whoever did this was not a plumber.....and he was just looking at what was stubbed out as the units were drywalled, one already had all the finish set
    Water heater over bathroom, no drain line or T & P . (check out junction box too)
    Flush valve a tad low, and 3/4 mip and exposed copper at connection
    We are allowed 5' trap arm here, but this is over 5', plus 180 change in direction and gotta luv the trap
    we are just getting started...........
    Re: some hack work for your enjoyment
    Compression nut burried in drywall
    I pulled toilet for drywaller to access, old cast iron ring stuck to WC when I pulled
    [ATTACH]12154[/ATTACH]
    Next two are not hack, but are unbelievable, this building was under pressure when I got there, and has been, this 3/4 is only 15' from meter in basement and it only had a small bead of water on it, not even dripping
    [ATTACH]12155[/ATTACH]
    closer up....after shutting down I just pulled it apart by hand.
    [ATTACH]12156[/ATTACH]
    New water heater they put in, vent against PVC and close to tracpipe
    [ATTACH]12157[/ATTACH]
      This was to kitchen sink, the 90 up was to get high enough for trap to clear toe kick. Count the 90's and I then look below....
      [ATTACH]12158[/ATTACH]
      as bad as this is, this is after I removed FRP and green board..this was readyf or finish
      1 1/2" to the left is other side of kit waste, there was a waste line there originally, but you can see by the clean pipe they "re worked" it.
      The other 1 1/2 stub out was added to the old piping...it was rough in for urinal, check out the urinal water supply
      and pressure tee on vent stack.
      [ATTACH]12159[/ATTACH]
      This is riser they inserted tee for urinal on.... it looks to be used for just a vent before, but now waste on santee on its back.
      and all that backing but they missed it all and had 10 deck screws in urinal hanger
      [ATTACH]12160[/ATTACH]
      Did I say 5' trap arms are allow, or 15', I just can't remember all them numbers
      [ATTACH]12161[/ATTACH]
      some fine pex crimping
      [ATTACH]12162[/ATTACH]
        More Pex crimp training photos
        [ATTACH]12163[/ATTACH]
        I re-attached their WC supply for your enjoyment
        [ATTACH]12164[/ATTACH]
        Now, that ring is a touch low...Hmmmm
        [ATTACH]12165[/ATTACH]
        This is what was installed, with 1 tapcon holding it down, and toilet was set
        [ATTACH]12166[/ATTACH]
          Looks like they was going for gold
            Couple of things. Elec. box overfill + . Liquid tight 6 ft. Max length,
            and wrong place for it to begin with. I would like to see these Pricks
            In a public stock in the center of town
              Maybe this was just their interpretation of the code?
              Ideal Plumbing
                Starting over is the only way to go
                  With a wrecking ball and a whole new build.
                    No vacuum breaker on the water heater.
                      Vacuum breaker on a water heater? Por quoi?
                        The cold water enters this heater at the bottom of the tank. The vacuum breaker should be on the cold line 6" (I think) above the tank. N'est pas?
                          I wasn't thinking of a bottom feed, but now that you mention it, I can see why one might be installed. They aren't required by our state plumbing code however, and I've never seen one installed here.
                            See what I saw today? A pipe rollercoaster.
                              From the IPC:
                              504.2 Vacuum relief valve. Bottom fed water heaters and bottom
                              fed tanks connected towater heaters shall have a vacuum relief
                              valve installed. The vacuum relief valve shall comply with
                              ANSI Z21.22.
