Apparently, duct tape does fix EVERYTHING!
  • Apparently, duct tape does fix EVERYTHING!
    Soooo, apparently the "handyman" who was doing some work at this poor old lady's home, spotted a leak (which he may have also caused to begin with) and offered to repair her main supply line from the meter to the house. She agreed....
    Luckily, someone spotted this before the guy could backfill his trench. All signs indicate he had absolutely no intention of ever mentioning this.
    My guess is he put a pick or shovel through it while digging. There seems to be a plastic bag under the duct tape....
    Oh, and she even had to rent tools for him to do the job (jackhammer and concrete saw).
    Ideal Plumbing
    Re: Apparently, duct tape does fix EVERYTHING!
    you get what you pay for. ..and sometimes a little less
      Duct tape is mm mm gooooood.
      Is that a regular solder joint on that coupling that's about to be buried?
      That's bad ju ju here in the frozen hinterland.
        She probably paid the going rate for a plumber...she just thought she was saving money.
          Looks like soft solder to me...
            Possible disaster was prevented...if that water pipe developed a leak, and the sewerage overflowed....
              I wonder why he even bothered to solder--he had a lot of duct tape.
                well any body knows you need to cut the ends out of a tin can and split it to cover the hole before one uses the duct tape,
                  To his credit, definitely a good way to fertilize, irrigate the lawn, maybe it was done for that reason.
                    No, use a plastic bottle--they won't rust away.
                      Perfectly acceptable
                      It's not like the poop is going to come flying out of the top of the pipe
                        no roots in that hole, so he was good to go. breid.................
                          Yeah, but you have to be careful these days. The plastic in the new Eco bottles is too thin and won't hold up to the weight of the dirt like the good old plastic bottles. The rule of thumb is to use three of the new eco bottles where you would use one of the old ones.
                          Don't forget to use a good grade of duct tape not the crap they sell at the big box stores.
                            Just as an update, it wasn't just the top of the pipe that was broken....the bottom of the pipe was split but the duct tape did a good job at holding it together.
                            Oh, and as everyone would expect, there was clay sitting inside the pipe. I can just see it now....pieces of clay would have eventually caused a blockage, and someone would have run a cable down the line, and been confused as hell when he pulled out duct tape on the end of his cutter.
                            Ideal Plumbing
                              soooo, apparently the "handyman" who was doing some work at this poor old lady's home, spotted a leak (which he may have also caused to begin with) and offered to repair her main supply line from the meter to the house. She agreed....
                              my guess is he put a pick or shovel through it while digging. There seems to be a plastic bag under the duct tape....
                              note per upc that water service should be running at least 12" above or to the side of sewer pipe !
                              JERRYMAC
                              E-MAILJERRYMAC777@GMAIL.COM
                              FIRE SPRINKLER CONTRACTOR,
                              SINCE JAN. 1989
