Shower stumper
  • Shower stumper
    Saw this on a "Boating Forum " LOL
    "The hot water in my house. If you run hot only it will run forever. If you add cold water to make the shower temp tolerable. The hot water runs out in about two minutes? Any suggestions of what the problem may be?"
    Re: Shower stumper
    there is two possibilities that I can think of, or even a combination of the two,
    but not enough info to make any kind of real determination,
    1. a faulty thermostatic balancing valve is malfunctioning, some way, (is there a tempering valve on the heater)
    2. some how the cold is back feeding into the hot water line in time over coming the hot water, (had this happen on a hand sink one time (and when another sink faucet was used it back feed in the one sink and cool the second sink hot water supply) ended up putting check valves in the hand sink so it could not happen, (this was on a hand washing sink that the shut off was not at the valve but on the mixed water, there are some add on faucet controllers that attach to the aerator so kids will not leave the water running,)
    for some reason the two Min's seems to make me think that the mix is coming from some place else than the shower valve it self, in other words it is taking 2 Min's for the hot water line to drain out of hot water,
      Re: Shower stumper
      Maybe turning on the cold water is taking away enough pressure from the cold line to reduce the output pressure of the heater.
      If it's taking away lots of pressure from an already low pressure system, that may be just enough to fool the user into thinking he/she has no water left at all.
      Ideal Plumbing
        Re: Shower stumper
        Usually if there's backfeeding hot water will push cold. What I would do, if it's possible (pipes buried in walls notwithstanding...) Feel the hot water pipe back to the water heater before you turn the cold on. Then once you've turned the cold on feel the pipes at the water heater.
        Although I suspect it's possible there could be some kind of control problem in the mixing valve. Since we don't know if it's pressure balanced, temperature balanced, and if temperature balanced is it paraffin based or bimetallic or some other technology? Sounds like a fun one though.
          Re: Shower stumper
          Are you making that up?
          I've never heard those terms before
            Re: Shower stumper
            He says It's a Non Pressure balanced 2 Handle Valve
            He also says it happens with all Fixtures ...
            Keeping my eye on this one ...
            Problem just started supposedly ...
              Re: Shower stumper
              Parafin based and bimetallic are terms used by Toto on there pressure balancing valves.
                Re: Shower stumper
                plumber:
                Yep just made em up on the spot.
                I understand there are many ways to skin a cat. Personally I wouldn't waste time skinning it, when a plastic bag, a brick, and a bridge over a river would be less messy. (OK bad joke but I can live with the guilt )
                There are several ways to create anti scald devices. Some have balancing pistons. Some thermostatic valves use a paraffin material which expands and contracts very rapidly with temperature to maintain a desired temp. Then of course the good old bi metallic method where spring pressure varies with temperature. Unless things have changed Taco zone valves operate using a paraffin base too. I imagine there are other methods which I'm not aware of.
                Apparently what kind of anti scald isn't an issue in this case because it's a two handle valve.
                  Re: Shower stumper
                  first thought: as with anything that makes zero sense, get on site and get some actual data instead of ho crap info.
                    Re: Shower stumper
                    put up the link for us to sea
                    SMELLS LIKE $$$$$$ TO ME
                      Re: Shower stumper
                      never mind
                      http://forums.floridasportsman.com/f...mbing-question
                        Re: Shower stumper
                        There are a LOT of "Hairballs" on that forum ... LOL
                          Re: Shower stumper
                          I stopped reading after the guy blamed it on a dip-tube.
                          I just see arrogance and ignorance coupled with money and more ignorance when I read their posts. No thanks son. I am pretty sure it's not good for me to bleed out of my eyes
