1 1/2" abs p-trap with cast in baffle
  • 1 1/2" abs p-trap with cast in baffle
    The one and only I've ever seen like this.
    will post a pic when I get a chance... looks intentional, not like a defect.
    literally has a baffle molded in blocking the flow path with a small slot in the center. Anyone know what this is supposed to be good for (other than clogging)?
    Re: 1 1/2" abs p-trap with cast in baffle
    A defective piece that got out the door?
      If it's the type I've seen it's not a defect...well a defect in design maybe.
      I have no idea why. I always thought it was kind of foolish but I don't have smart people papers.
      I've kind of thought it must have something to do with turbulence or because it's such a small trap they put that in as sort of a gate so more water would have to evaporate before causing a stink??????????
        I had the same thing , on two abs tubular traps in oct of this year , so alex you are not the only one
