Thermal Expansion Control
  • Thermal Expansion Control
    What are your methods? Do you consider your methods the best method of control? Do you just use whatever method is readily available that will satisfy your plumbing code?
    I see faults with thermal expansion tanks.
    Re: Thermal Expansion Control
    I personally use a variety of control methods depending on the home.
    Watts makes several different types.....here is a link to the page. http://www.watts.com/pages/learnAbou...n.asp?catId=64
      WHAT'S THERMAL EXPANSION ? I use Pex !
        When a substance is heated and it expands. Pex can be ruined by thermal expansion. Click on the link and Watts will do a much better job explaining the majority of it.
