drilling out a pvc hub
  • drilling out a pvc hub
    I got a call tonight at 3:40 pm from a customer which detoured me from seeing my newborn grandson for a while. Normally they're a good customer. (Timing is everything)
    Anyway, it turns out that the maintenance guys at this facility broke a fitting going into a 4x2 wye. Since I had a special wheeler drill bit designed to cut out the pipe from a hub (pipe hog) the repair was a piece of cake.
    Without the bit the alternative would have been to try and remove the pipe from the hub with a reasonable chance of destroying the hub on the 4x2 wye. Or simply replacing the 4x2 wye. Which I didn't have on the truck.
    After the repair I resumed my trek to visit my new grandson.
    Re: drilling out a pvc hub
    Nice job...whats with the stub of pipe?
      Nice! ..Those bits look good. I had a set of ram bits .The first time I used the 3" one it stripped out the bit where it bolts to the shank .. They suck..Maybe it was a bit of user error but anything that breaks the first time you use it you have to bash...just my .02
        The broken pipe is intended to drain a commercial washing machine. Apparently the people who operate the machine let things such as knives, spoons, forks, etc. get into the wash machine and they plug up the drain so the maintenance people want a Mission type connection there to aid in access. I ended up installing a mission coupling and a 2" trap with a union. It's back in operation for morning but the installation as it is isn't legal so I need to talk to management about that in the am. (They were already gone for the day). I really need to bust up the floor and install a good sized floor drain to provide an indirect connection to the DWV system.
          Clothes washer, dishwasher....What's the difference?
            You really don't want to put dishes in the clotheswasher.The spin cycle can wreak havic.
              Those bits are cool. I use them on kitchen remodels. The hack handyman cuts the pipe on the drain back to the hub, I use the bit and a new hub is born.
                you really don't want to put dishes in the clotheswasher.the spin cycle can wreak havic.
                that explains all the egg yoke on his tie
                  Originally posted by toolaholic View Post
                  "Egg yoke on his tie"
                  That was a Patsy Cline top ten wasn't it.
                  Real tear jerker if I remember right.
                    Good job Geno.
                    Be nice to have a set of those.
                    How's the grandson?
                      Nice to have a set of those.
                      A $40 heat gun would have gotten you the same result
                        Crap,I only have a $20 one.
                          Prices are higher in D.C..
                            Those look way better than the crap I've used and broke. Congrads on the grandson.
                              In the wrong hands that could be dangerous. Just like a ram bit.
