Figure Five Fitting
    Re: Figure Five Fitting
    I like them on their sides. Thats when I pull out my viking jetter and use the cornering nozzle to make the turn and get the line open.
      MoJourneyman...this particular setup that got me started was in a medical office...so they are already up in a roar at opening the sewer and stinking up the joint...my goodness i think they would faint if i told them i got to cut in a different access...let alone i'm not quite crazy enough to try to cable something that high up in the air from the ground....
      Derek
        not sure a drop head would work in this situation...but hell who knows...
        Derek
          Seweratz...jetting was not an option as I was in a second level finished bathroom...but after taking that cap off it might have not made much difference!
          Derek
            Originally posted by TheMaster View Post
            Looks more like a double combo to me than a double wye and nothing like a figure 5
            Than I guess we're going to have a real hard time with a "Figure 1A"
              Ha...now that's funny!
              Derek
                Figure #5
                For vertical use only
                The internal slope of the figure #5 is such that a cable is forced downward and should not run horizontally through the fitting.
                Figure #1
                Same as above
                A couple years ago I had a problem with two toto drakes plumbed back to back using a fig #5 and closet bends. When one flushed the dam on the other would bubble and ripple (which turned out to be a problem Toto was aware of). Had to reconfigure the below floor waste, capping one inlet and adding a combo and healout so each wc was on it's own riser.
                • #23
                  Originally posted by Plumbus View Post
                  Figure #5
                  Figure #1
                  Same as above
                  I agree it should be vertical only but code does allow horizontal which is just stupid in my opinion...thats why i think Drtyhands is right about using acomby upstream with a wye to an eighth downstream....
                  Derek
                  • #24
                    It's not code in UPC country. The reason is that there is no way to get fall from both inlets in a horizontal position. To achieve that, the manufacturer would have to cast the fitting so the two inlets were 176° center to center when stood on end. But, they don't.
                    • #25
                      We are also UPC... but the inspector looks at the plans then the plumbing and say looks good...even if the plans come from out of state and from a different code...so i cant figure out how that works exactly...
                      Derek
                      • #26
                        A couple years ago I had a problem with two toto drakes plumbed back to back using a fig #5 and closet bends. When one flushed the dam on the other would bubble and ripple (which turned out to be a problem Toto was aware of). Had to reconfigure the below floor waste, capping one inlet and adding a combo and healout so each wc was on it's own riser.[/QUOTE]
                        a double figure 6 would be the right fitting with a built in baffle. the figure 8 is the horizontal version of the vertical figure 6.
                        see catalog page 12 and 13. http://tylerpipe.com/documents/catalog2008web.pdf
                        • #27
                          Hmmm...very interesting...the only problem I see is a figure eight does not give a 4" branch outlet only a 2" which a 4" in my case is needed. I do like the ideal of a figure six but would still have concerns that with one side only being a toilet about 60 to 65 foot away and the other side being a single sink with little usage that the baffling still might create the same stoppage...but having said that it does appear that a figure six would make the cable go the right direction and unclog the system...which is better than standing on a 12 foot ladder dumping sewage out of the top of it! I assume these fittings are still on the market in cast iron? Just notice that a figure six is not in a branch 4" as well...crap...
                          Derek
                          • #28
                            both the fig. 6 and 8 are designed for toilets. the 2'' connection is a vent ony. that contains the baffle and you can't connect a waste line to it.
                            the branch lines come in either a 3'' or 4'' single or double.
                            • #29
                              Figure #5
                              Figure #1
                              Same as above
                              It should force a cable downward, but it does not. The cable may angle a little downward but not enough, and catches the slop on the other side and comes up the other side. But thats really shouldn't be a problem since my code states pulling a water closet is not to be considered a clean out. If the new construction plumber puts a clean out above that fitting all should go well.
                              • #30
                                Okay....I am retarded....I read your link at 6 a.m.....now that I am awake I see it now...thanks so much...thats awesome!!!
                                Derek
