Figure Five Fitting
  • #31
    Re: Figure Five Fitting
    Seweratz,
    This is same here on pulling a toilet...thats why I wish they had extended the vent portion of the fitting up thru the floor to be able to cable it straight out...but code is code and code is minimum...
    Derek
    • #32
      After this read,I would never use one, never have. Sounds like a dice roll!
      • #33
        Sums it up...bad for drain cleaners...i don't use them as well
        Derek
        • #34
          both the fig. 6 and 8 are designed for toilets. the 2'' connection is a vent ony. that contains the baffle and you can't connect a waste line to it.
          the branch lines come in either a 3'' or 4'' single or double.
          If you're only one story, the extra 3" or 4" riser on the fig #6 is kind of useless.
          That being said, it's too bad they don't (as far as I know) make either fitting in plastic.
          • #35
            I've used them on back to back wcs in tilt up warehouses for years and never had a problem.
            • #36
              Good place for them! Lets call them warehouse fittings from now on.
              • #37
                Ironically, the toilet in a warehouse bathroom occupied by a tenant gets more abuse then most any other save maybe one in a gas station or a public restroom. Not having plumbed commercial back to back baths since the introduction of ultra low flush toilets, maybe the Drake problem I described with a residential bath with back to back Toto Drakes might now be a phenomenon experienced with all ultra low flush wcs if plumbed this way.
                • #38
                  you better have a figure 6 or 8 with a baffle if you do back to back pressure flush or sloan valves. if no the other person will have a free bidet washing when you flush
                  • #39
                    you better have a figure 6 or 8 with a baffle if you do back to back pressure flush or sloan valves. if no the other person will have a free bidet washing when you flush rick.
                    Much cheaper than a Washlet.
                    • #40
                      speaking of washlets, I bought my wife one the other day.
