Figure Five Fitting
  • Figure Five Fitting
    Are figure five fittings allowed in your code area or do you even use them in a complete horizontal position? This is a more frequent practice here nowadays to put these in and one branch will be a toilet and the other side is a fixture that does not get much use. So whats happening is paper is clogging in the outfall of fitting. Then when you cable the drain the paper is so packed in there it makes your cable jump to the other side...and of course you can't go through the top because its capped and not accessible. This is so frustrating when the line is over heard 14 to 16 feet in the air or under concrete. So any input on this practice?
    Derek
    Re: Figure Five Fitting
    We're still putting them in.You have a flexble leadern the end of your cable?
    Edit:
    Vertically
    Last edited by drtyhands; 01-03-2011, 08:34 PM. Reason: Didn't catch it first read through
      Hey Plumberscrack,
      Now that I have your 18" leader for my 7/8" sectional,have you ever made a lead weight that can be fastened in the end to pull a bit down into the figure fitting?
      All it woud be is a lead kitchen faucet hose wieght with maybe longer screws and a wad of macguyver tape.
      Sewer Ratz?
        I do in fact have a flexible leader...first thing I tried...with several different cutter bits...not much luck...what are you suggesting involving a flexible leader?
        Derek
          I was actually hoping you could get something to drop low enough on the leader to catch catch an edge.You try bending the end of the cable at a 45 yet.
            I have to ask what is a figure five fitting?
              i use a inner core cable so you know how fun that is trying to bend...plus the fitting was 65 foot away going thru a toilet flange then thru two more 1/8 bends...i dunno i guess i just think it should be like a cross...only standing up applications....
              Derek
                the rick reverse auger is the trick to getting it to go down. bend a 45 and use a locking vice grip with the handles in the same direction as the offset. this way you know where your drop leg is.
                once you have it in. take off the vice grips and run it in your machine. a sectional is easier to do that trick with
                  Seweratz...you might know it as a double wye....and Rick...i use a k-7500...don't have a sectional
                  Derek
                    Here
                      ahh a double wye. Eel makes an adaptor to use their 1 1/4 cutters on the 3/4" cables. They also make a drop head fitting to use with their 1 1/4 cutters.
                        suspended overhead, i'd cut the line open for closer access. buried in concrete, I have a leader for my k7500 I heated and bent to a 45, make enough passes at the fitting and it is bound to make the drop.
                          You're right.Typically one will see comby upstream with a wye to an eighth downstream to make up the difference.
                            As it probably should be in my opinion...
                            Derek
                              Looks more like a double combo to me than a double wye and nothing like a figure 5
