Kinked Soft Copper T&P Relief Line
  • #46
    Re: Kinked Soft Copper T&P Relief Line
    I did, when I made that post you had not clarified the regulator at that point.
    • #47
      not dnc but a tea bagger. breid...........
      • #48
        Originally posted by HVAC HAWK View Post
        is it the type with a little ball in it ,i cant make it out
        Originally posted by TheMaster View Post
        Yes I believe so...I've never had to repalce a regulator because of a malfunctioning vent inside a home.
        is it this type
        http://www.maxitrol.com/PDFs/JulyNewsletter2010.pdf
        it will not shut off the gas because the regulator is on its side
        • #49
          is it this type
          The door will not shut with the regulator on its side. I turned the gas off at the meter and disconnected the regulator and valve to clean out any trash that could foul the regulator. I always blow out the feed to the regulator and check the pressure before the regulator.
          So when in operation the valve is in the A position not in position B on its side.
          • #50
            Not to stir the pot again and I realize that that's the way it's done down there but just how much less expensive is it really to put the regulator outside and pipe larger to the appliance? Hell though I hate the crap, you could at least go from the 2nd stage regulator (outside) to the appliance with uggg... CSST and save some time. I really can't believe that they let you guys do that. I'm here to tell you that if anyone around these parts did that the inspector would probably have us before the board for incompetence. Even though everyone does it like that I think that I would stop before something happens and everyone ends up standing before a judge. Liability is everything these days.
            • #51
              The new systems I install do not look like that Nhmaster. The new work I do the customer is explained the pros and cons of different materials/systems and I give my opinion. In my opinion a low pressure system is the safer system hands down. I have installed low pressure,medium pressure and high pressure systems with various materials. Now with repairs.....selling a repipe for 2-3 grand and chopping the house up doesn't sell to well these days and to be honest I dont waste my time offering it. So I'm usually just working with existing pipe systems and thats that.
              I personally do not like gas and will not have it in my house. I tell people that all the time
