Kinked Soft Copper T&P Relief Line
  • Kinked Soft Copper T&P Relief Line
    The door would not even shut to the room.
    This heater has been like that for 7 years. The thermo was set to the max. 75gal nat. gas. The homeowner said after the plumber left she tried to shut the door but it wouldn't. It was hitting the relief line. That is not the reason the relief is kinked,the bad kink is near the backside of the heater and not in a location that would be caused by the owner trying to force the door shut. Crappy work done with copper. Who would have thunk
    I asked why didn't she call him back right then.....said she felt sorry for him because he was real fat and slow
    I immediately dropped that conversation and went to work giving her options to correct the problem.
    Re: Kinked Soft Copper T&P Relief Line
    That's a beauty.
      Kink? That's not a kink!
      Thats a "flow reduction compression".
      Obviously this hack....ummmm,,,Plumber was thinking ahead. He knew it would take the HO a long time time to close the door so he added this "flow reduction compression" to give the HO adequate time leave the area if the T&P trips.
        Would be interested to see your correction...nice job for a fat guy...ha...
        Derek
            Very nice and neat and clean....you must not be a fat guy or lazy....( no disrespect to overweight people intended)
            Derek
              if he was on electrician that would been done with the bumper bender. lol. breid...................
                what's it do for combustion air with the door closed ?
                  It has a vent at the top of the door and the bottom.
                    What hangs that 3/8 soft copper gas line so that some kid does not grab hold of it and snap it off?
                    That is an installation that is a shining example of why there will never be a unified code, because 90% of jurisdictions would never allow a high pressure regulator to be installed in a residential application. The regulator should be outside the structure.
                      Thats not high pressure its medium pressure. Nothing would stop a child from tearing the gas line out...what would keep that same kid from turning on the stove burner and letting raw gas out into the house?
                      Nothing
                      Does the code allow log lighters? Sure they do and thats just a steel pipe with holes in it with a manual valve to control flow....no safety other than removing the key from the valve and then your relying on that valve to hold.
                      Log lighters are contrary to common sense but its legal. i would never leave an opened ended pipe not capped on a live gas line just because the valves off and the handles gone(key removed). Code approved baby!!!!!!
                        if it's not a high pressure regulator then there is no way there is enough gas volume running through a 3/8" copper line to carry a 35,000 btu burner.
                          Thats why they have a test port on water heater control valves....so you can fire them off with a manometer attached to check pressure drop.....it checked out.
                          Click on this link and then convert CFH to BTU(note the lenght of 3/8..in the chart its 10') And they allow for fittings and pressure drop
                          http://www.copper.org/applications/f...s/table04.html
                            Anyone ever see the size of the internal gas way that leads into a 1/2" regulator from the inlet?
                              how come there is no vent to the outside on the regulator
