Putty potty
  • #31
    Re: Putty potty
    Originally posted by TheMaster View Post
    I've found slip joint drains under fixtures that had putty beads around all the joints. Anyone do that here?
    Yup,sometimes somethin's messed up or some manufacturers defect for one reason or another.
    • #32
      Re: Putty potty
      I might try it on a pvc fitting and see how it works. No need to cut a fitting out if putting around the outside will stop the leak.
      • #33
        Re: Putty potty
        How is this relative to the slip joint application to my post you quoted?
        Or are you just bopping around.
        • #34
          Re: Putty potty
          Originally posted by SewerRatz View Post
          About three, I do seal around the base of the water closet with putty. I clean the flange off set the water closet with out the putty first, then take my pencil and trace out the outline of the water closet. Then I lay my putty seal on the flange and then run a bead of putty around the traced line.
          Wouldn't putting the putty on the toilet 1st save the step of having to trace the shape of the bowl?
          I might have just saved you alot of touble.
          • #35
            Re: Putty potty
            wELL IF IT WORKS LIKE THAT FOR SLIP JOINTS AROUND THE OUTSIDE WHY WOULDN'T IT WORK ON PVC ON THE OUTSIDE?
            Oh sorry for the caps lock,but I'm not re typing it
            • #36
              Re: Putty potty
              I'm sorry I misunderstood I thought you meant under the nut(like my rash).
              You wanna see it?
              • #37
                Re: Putty potty
                Ignore List.
                • #38
                  Re: Putty potty
                  You wanna see it?
                  No problem,figured it was a misunderstanding.
                  For sure not I dont deal with other mens junk.... rashed up or not. Try a soaking solution of thanksgiving gravy and follow with cold milk.
                  • #39
                    Re: Putty potty
                    Ignore List.
                    Ignore
                    or
                    Avoid
                    • #40
                      Re: Putty potty
                      Ignore
                      or
                      Avoid
                      I do not have to avoid what I cannot see.
                      • #41
                        Re: Putty potty
                        Unbelievably I was sold some wax rings recently that went bad. ???
                        These rings got hard as a freaking rock, warming them up did absolutely nothing. You could swing a hammer at one and it would indent it, but you would not hit the floor with one swing.
                        Knowing this latest revelation, I'm pretty effing pissed because if I start getting leaks on those rings because they are contracting under the toiet, I'm going to cast a spell down upon thee.
                        • #42
                          Re: Putty potty
                          Seen it plenty, never done it myself though.
                          Ideal Plumbing
                          • #43
                            Re: Putty potty
                            You wanna see it?
                            Maybe some putty would help that too? Who knows?
                            Ideal Plumbing
                            • #44
                              Re: Putty potty
                              What brand were these Dunbar?
                              • #45
                                Re: Putty potty
                                Wax, WAX son all the way.
                                Show me soft putty, and I will show you the container it came out of hiding behind your back. In my entire plumbing career, I have yet to come across soft putty in the field. That crap even goes bad in the container it comes in for crying out loud. Why on earth would you use a product you KNOW is going to go bad 100% guaranteed?
