Tile Shower Drain?
  • Tile Shower Drain?
    Which types do you use? Not many designs available at the supply houses here.
    When I say "designs" I'm not talking about how pretty it is. I'm talking about construction and installation.
    Just trying to learn about the best options.
    Thanks.
    Re: Tile Shower Drain?
    Standard EZ test
    Custom Zurn Z-415 (comes with round or square top)
      I use the plastic or cast iron bolt together with a compression type seal onto the pipe or pour some lead. these are for pan showers and I use oatey shower liner with a pre-slope before the pan is installed.
