new fill valve
This topic is closed.
    Re: new fill valve
    Originally posted by Cleanmen2 View Post
    Rick, have you ever tried the Geberit valves. I used to swear by the fluidmasters but I had a bad run with a batch. Also found that the working pressures on the Geberit were better suited for pump systems.
    can you post a photo or a link. don't think they sell them in my market.
    fluidmaster is a local company/ 60 miles away.
    a couple years ago i did a service call for a homeowner that had a runny toilet. i installed a fluidmaster ballcock and she literally broke down in tears
    turns out her grandfather was 1 of the engineers that invented that ballcock since he was no longer around, she called her mom to get the whole story.
    pretty small world in the life of a plumber
      Re: new fill valve
      I have used the MJSI fill valves, installed them in my house to test. not worth the expense, 2 of them failed in under 12 months, running.
      Fluidmaster has a solid float design and that float holds water and hangs down causing the toilet to run, poor design. I replace at least 3 a week.
      I use the Brasscraft BCT015H
      Excellent design, cup float, 10 year warranty. Excellent price also, and not sold at home depot or big box stores.
      what more could you ask for?
      Robert
        Re: new fill valve
        Could you go into a bit of detail here....I'm all ears This should be fun.
          Re: new fill valve
          Every Fluidmaster ballcock is tested before it leaves the factory. Fluidmaster own their own mold machine too. Quality assurance
            Re: new fill valve
            Originally posted by BCPLUMBER View Post
            who here has installed one of these fill valves?
            i just installed one @ my house, these are really nice. definitely my new favorite!
            they have a valve on the refill tube, finally someone figured out that you dont need all that water blowing down the drain.
            and they are cheaper than the fluid master 400
            found them at home depot
            http://www.gomjsi.com/products/overv...droclean_hc550
            I came across these valves that I had to take out due to them not working. I always thought the home owner bought them at the HD. I put in my Mansfield ballcock and they where very happy.
              Re: new fill valve
              i've tried the brasscraft and of course they are a fluidmaster type design. problem is they don't have the fluidmaster reputation. good luck getting the 10 year warranty. they will send you the part. you still get stuck going back for the running toilet.
              ps. i have the better part of a case of those brasscraft. i'll trade you my brasscraft for your fluidmasters any day of the week
              i'll even throw in some american standard smart valves too. guess what. when you call them and tell them their smart valves are junk and leak, they send you a fluidmaster for a replacement.
              brasscraft should stick to angle stops and let fluidmaster do what they do best. make ballcocks
                Re: new fill valve
                Although this new valve seems to have a few nice features, I would be a little worried about reliability. I'm not saying that it's not a good valve, I'm just saying I sleep better at night knowing the fluidmasters I'm using are so damn reliable and last forever. I'd take a customer's trust over a few nice features of a "new" (and unknown) valve anyday.
                Ideal Plumbing
                • #23
                  Re: new fill valve
                  as I agree in a lot of ways about the fluid master I do have a brasscraft fill valve in my toilet I installed in my house when I moved in 11 years ago and still running strong
                  SMELLS LIKE $$$$$$ TO ME
                  • #24
                    Re: new fill valve
                    Not so sure about the "last forever" part. I take out several every month that will no longer fill. After 8-10 years (much less if the customer was stupid enough to put chlorine tabs in the tank) the fluidmaster will snap near the base and start to run full blow. If you take the tank lid off without shutting off the water first it will rocket to the ceiling. I took 5 out today that I was able to snap like a pencil (outer and inner tubes).
                    That's why I never replace only the gasket in the top or even the whole top of the valve leaving the old base.
                    Don't get me wrong, all of the above is not a rant. One of the things I dearly love about the Fluidmaster is I am assured of repeat business. When they won't fill any longer the customer becomes quite flabbergasted and has by that time forgotten it is one I installed just a few years ago.
                    Having said (typed) all of that, I still only use the PRO45Bs with a Wolverine flex supply w/metal supply nut. Except, that is, for the occasional 1B1X in the 1 pc toilets.
                    I like the Pro45b because of the brass shank, filter screen, pressure reducer/regulator? so the refill won't keep the flapper from dropping, and last but not least, the refill tube clip is SWEET.
                    One thing I don't like is on certain toilets, you can't raise the FM up high enough without hitting the tank lid and so the water level is left a little low.
                    • #25
                      Re: new fill valve
                      You would have a deal if I had any fluidmasters on my truck. I havent had a fluidmaster on my van since I got you that case years ago!
                      As for American Standard, anything American Standard sucks! Sad, because they used to be a reputable company.
                      Thanks-
                      Robert
                      • #26
                        Re: new fill valve
                        Just go into your local hardware store ferguson and buy a fluidmaster and a brasscraft, if you have been in this trade for even the shortest period of time you know what I am talking about. Buy 1 of each and compare.
                        I am sure you have taken out plenty of fluidmasters that have been bogged down with water.
                        Robert
                        • #27
                          Re: new fill valve
                          Just go into your local harware store ferguson and buy one of each, compare them, you will see what I am talking about.
                          If you have been in this trade for any period of time, I am sure you have removed a fluidmaster bogged down with water
                          Robert
                          • #28
                            Re: new fill valve
                            Ok I have no clue what your talking about. A fluidmaster has a hole in the top and bottom of the float.....noway for it to "bogg" down with water.
                            Please get a fluidmaster and inspect it and maybe take a few pics of how it "boggs" down. I know your a seasoned pro and I'm probably just over looking somthing as i just have 25+ yrs experience.
                            IMO your mistaking another malfunction as a "Bogg" down of the float
                            • #29
                              Re: new fill valve
                              Master, give me a break.
                              Pull a fluidmaster out that isnt rising anymore and it will have a huge amount of water inside the float. little hole top and bottm does not help. Its junk and it holds a ton of water.
                              Check a brasscraft, no way this can happen.
                              Robert
                              • #30
                                Re: new fill valve
                                Simply put...your wrong. Now I will leave it alone as its just
