Testers Page Title Module
  • Testers
    Could someone point me in the direction of a great voltage tester and a continuity tester for diagnosing of heating systems?
    Re: Testers
    I have a Fluke (its so old cant find model)
    Also have Amprobe brand
    Both have been good meters,although the Fluke will check capacitance as well.
    Huck
      Re: Testers
      http://www.ueitest.com/productlist-clampon.html
      I have the DL369, I didn't need the temperature probe because I have a clamp on thermometer.
        Re: Testers
        Mostly have Fluke stuff now and a couple of reliable Sperry analog's just in case but for HVAC work I really like Fluke's stuff
          Re: Testers
          my CO meter is Fluke, but I hadn't made the leap to fluke volt meters yet.
            -15 or -20 deg f
            i live in indiana. my fluke #12 just died.it lasted a lot of years. getting afluke #113. do you leave your meter in an unheated truck or building? if so you might want to check for the "storage temp" not the "operating temp". #113 is good for -22 deg f. flukes have by far the best low temp storage temp that i could find. before #12 i would go through a few every winter. i leave mine in an unheated truck at night. just a thought. breid..............
              Re: Testers
              UEI DL 250...No problems!
              Derek
                Re: Testers
                I always wondered if this was a good one/idea.
                http://www.fieldpiece.com/
                  Re: Testers
                  storage temp is-4 deg f on uei dl250 spec sheet. you are about the temps as us. do you leave it in the cold? i just read the specs. breid...............
                    jc
                    i've never seen that puppy before. i can't help you. try posting that at www.heatinghelp.com. breid..................
                      Re: Testers
                      I leave it wrap in a towel in its case in the van...10 years old and still the original batteries!
                      Derek
                        jc
                        hvac-talk.com. some chat on their forum about fieldpiece. breid...............
                          Re: Testers
                          I use an Ideal ...like this one.
                          http://www.computercablestore.com/4_..._PID45826.aspx
                          But I dont work on HVAC systems. Just water heaters and grinder pumps..plumbing service work.
                            Re: Testers
                            I use a Fluke and Amprobe brand. Only had to change the battery once because I forgot to turn it off.
                              Re: Testers
                              Fluke and Amprobe here too. I love the capacitance tester.
                              Frequently asked questions about pumps and tanks.
