A.O. Smith pain
  • A.O. Smith pain
    Built in 8-06, this thing is pre FVIR, Power vent...Hot shot.
    Go on a no hot water call.It is flashing the classic '6' error code so I clean the flame sensor rod,put all back and it fires after *tightly* putting the inner and outer doors back on.
    I was called 3 days later same thing.
    Show up and it's running?!Thought ok....
    Called back in 2 days..failed again.
    Well turns out that it is now intermittent.
    Is the flame sensor out of specs?
    I called tech support and they were already gone for the day.
    I install Rheems.
    Ideas?
    Re: A.O. Smith pain
    Take a vacuum with you and clean the vent/fan system good.
      Re: A.O. Smith pain
      Pull loose or deal with it mounted?
        Re: A.O. Smith pain
        Been awhile, but if I remember it is just a screw clamp on there. So I would say pull loose.
          Re: A.O. Smith pain
          I install Rheems.
          Ideas?
          Jay, the water heater is under warranty. Call AO Smith and they will send out a local company that only handles warranty work. They'll have the parts on the truck.
          I just installed a hot shot on Saturday.
            Re: A.O. Smith pain
            I didn't look at the date like I should have.
            Might be the thing to do.
              Re: A.O. Smith pain
              They are having issues with the wiring harness from blower to thermostat on some models.
              Post back what the cure was.
                Re: A.O. Smith pain
                Maybe.
                The water heater I replaced on Saturday had two gas valves fail and a flame sensor fail, all repaired under warranty. Then the tank failed six months after the warranty expired. The new AO Smith Powervents have ten year warranties though so I went and installed another one.
                There's another PowerVent right next to it piped in parallel. That one has never had a problem. Go figure.
                  Re: A.O. Smith pain
                  Originally posted by geno gardner View Post
                  Maybe.
                  I have pretty much been making every effort to stay away from State & A.O. Smith. There multiple part, intricate, efficient assemblies seem to have alot of things that go wrong.
                    Re: A.O. Smith pain
                    I'm an American guy myself....but definitely call them and let warranty cover it
                    Ideal Plumbing
                      Re: A.O. Smith pain
                      I hate A.O. Smith and I really feel your pain brother. I had a pressure switch on the blower motor do that one time.
                        Re: A.O. Smith pain
                        As Dunbar was saying you want to pull the wiring harness loose from the bottom of the intelli valve. If it is brown or looks burned it needs to be replaced. The parts are warrantied for 6 years but the labor is only one year. Your first year AO service tech might have the parts but he will charge labor if over a year old.
                          Re: A.O. Smith pain
                          I found that A O Smith gas water heater had to many problems...I stick with Ruud/Rheems!!!
                          Derek
                            Re: A.O. Smith pain
                            What Dunbar said. also polarity at the outlet will haunt a water heater. at least that is what B/W says. Don't forget you are dealing with low voltage so any corosion on connections can cause trouble. also make sure the flame sensore is in the flame good . it may need to get tweeked into position.
