Vessel lav install
  • Vessel lav install
    Re: Vessel lav install
    Looks like it's from the future
      Hope that duplex Elec. recep. is ground faulted up stream !
        Don't you just hate putting in fixtures like that?
        Will Rogers Plumbing
        Moore, Oklahoma
        405) 323-2852
        www.willrogersplumbing.com
          I kinda liked it. Not the fixtures but just a change from the ordinary. Only took 20-30 minutes to install it all. I went last friday and disconnected the old one. The granite guy ripped the old top off and installed that granite. He drilled the holes. I went today and installed the lav/faucet.
          The faucet has a brakcet with two nuts that hold it to the top and braided stainless lines that screw into the botttom of the faucet. The vessel sink installs with the pop-up anchoring it to the top with the nut for it on the bottom of the granite. Very quick and easy install.
            Do you have to go in the kitchen to shave
            Or would you have to wipe it out every time so you don't leave spots
            I have 2 more of them to put in on a remodel I'm doing ...
            Absolutely worthless
              here is one from the past,
              we will finish building the cabnet in later, but it matchs the syle and the era of the house.
