Testing a thermocouple
  • Testing a thermocouple
    I decided to delete all my posts.
    Re: Testing a thermocouple
    Good job!
      OK, I will bite
      27MV was the reading, Is that an acceptable reading, what is the normal range? What is the minimum MV reading a water Heater gas valve is looking for?
        I believe its 25- 30 is acceptable...
        Derek
          Glad to see I'm not the only one that tests them. It is such an easy test to find out if the thermocouple is weak.
            Originally posted by TheMaster View Post
            Replaced this water ehater with a new one Saturday evening. I used my torch to heat the thermocouple with my test meter set to the millivolt setting. Atttached the alligator clips,one to the copper and one to the point of connection as the picture shows. The thermocouples maximum output was 27mv.
            Thanks. That's good info. I have a little device I screw onto the thermocouple. If the thermocouple doesn't hold the plunger down while being heated it's bad. I like your way better.
              I'm sorry I missed this. Nice work.
                Great read for all Master Thanks Tool
                PS Is there an ez way to find the M. Volts For individual W. Htrs. and Direct Vent Heaters ?
                  i like the video . they r so cheap i think the best test is a new one
                    Yep, me too.
                      Me too
                        I have a pretty expensive TC tester but I don't think I've used it in 10 years except for teaching.
                          I was thinking the same thing, never needed to test one and never will. With the new controls now it's pointless. If someone really wants to keep their old W/H then I'll replace the thermocouple to see if it works just like I have for years.
                            I carried the coil from a MR2 safety for about 20-years and then lost it. Now I have to use my millivolt meter.
                              Yes I was thinking its better to guess and just change the part and see what happens!!!!!!!
                              Me too! Pilot not staying lit, change thermo couple, stays lit, I'm done.
