Dig it
  • Dig it
    I did not realize how much I use my Shop Vac until it smoked today
    -Pot holing for broken yard lines / mud sucking
    -Clearing shower drains
    -Water clean-up
    -Clearing water from copper to solder
    -Dust / Air filtration when running the Hilti Hammer on indoor concrete
    - Indoor light hydro excavation or just fill removal
    I also clean up with it
    Re: Dig it
    And here I thought you where starting a thread about my exavator.
      Re: Dig it
      Give her a good burial Bill sounds like she deserves it.
      Would you like for the forum to hold a moment of silence?
      Good luck getting P-Ricky to abide
        Re: Dig it
        I like your digger. Looking into those.
          Re: Dig it
          It's a baby!
            Re: Dig it
            Originally posted by MoJourneyman View Post
            It's a baby!
            Small digups, that kind can be great. No trailer.
              Re: Dig it
              I have the 12" bucket a 24" wide bucket which I split in half trying to tear out a 100 year old oak root ball. Cost me $150 to get repaired. I also have a 36" wide backfill blade. It will dig down 8' 9" with no issues.
              Now as far as wet vacs go I been abusing a Ridgid WetVac that has the option to take the motor off and use it as a leaf blower. I to use it for indoor hydro excavating, also on window well drains, use the rod to break up the mud and rocks and suck it out with the vac.
                Re: Dig it
                we used a terramite for everything when I lived in your neck of the woods J.C., that little guy is probably great out there. for some reason I pictured Chicago as having the same rocky clay mess to dig in that we do here. The more I actually stop and think, I'm probably very wrong.
                  Re: Dig it
                  Mojourneyman, I have done 100' long trenches from 3' deep to 8' deep with this guy, in the hardest clay you ever seen. I too have used the terramite, the dig overpowers that little guy by a ton.
                    Re: Dig it
                    I had to use a Terramite once. I recall that one being pretty weak also.
                      Re: Dig it
                      I just looked at the dig it the other day, but the front wheels looked to wide for most of our city jobs.
                      Seattle Drain Service
                        Re: Dig it
                        The 148 like the one I own the front wheels come off and you put a set of caster wheels on, and the rear wheels swing inward to make it wide enough to push through a 36" wide gate.
                          Re: Dig it
                          I have a model 158 which is nearly identical to the 148 but the wheels can not be removed so it won't fit through narrow spots. It is nice to be able to hook up to the truck and drag it where ever its needed and no trailer needed. Also, here in NJ it is considered construction equipment and needs no registration or tags, so that saves a couple bucks too.
                          With some 1/4" plate, some angle, and a little welding on my part I made a backfill blade that is 36" wide and I can attach w/o having to remove the bucket. Pops on and off in just a minute. I have a 10" bucket but thinking about getting something a little wider.
                            Re: Dig it
                            -Water clean-up
                            Sorry for your loss Bill.
                            I feel your pain. It has been a while since I tragically lost Mother Suck-ah in a milk truck incident at a farm. She will be sadly missed but it turns out she is an organ donor.
                            I have been saving her upper half (motor) in a secure area(AKA. the shed)
                            I have recently purchased a piece of plastic called a vacuum. It's lower half is just like Mother Suckah's. When I am emotionally ready, I will merge the upper half of Mother Suckah to the plastic, and hope that Mother Suckah's personality takes hold.
                            Is it wrong to be emotionally attached to your tools
