Tankless water heaters
  • Re: Thankless Tankless water heaters
    Originally posted by MoJourneyman View Post
    /Raises mitts
    bosch electric tankless heaters, gutted them out and put in an 80 gallon electric. their electric meter looked like a welder fired up everytime they kicked on the hot tap.
    Unless your on peak metering it still takes the same KW which means the same $ to raise 40 gallons 60 degrees
    Pay quick or over time, the meter will still spins the same distance.
    • Re: Tankless water heaters
      true, but the difference is the tankless electric requires a very large panel and wiring. doesn't hurt to have a nuke power plant next door.
      a reqular tank is more like 4500 watts. pretty simple to power the tank.
        Can anyone tell me the best tankless water heater to sell to my customers. I have an the opportunity to install about 25 a month. I speak to plumbers daily while promoting EasyCAM and everyone says they work great when used with gas but no one seems to be thrilled when it is powered with electric. The tankless heater has a reputation of breaking down a a few years with the cost of the repair being equal to the cost of replacement. Where's the value???
          stick with selling cameras.
          if you really don't know the difference between an electric tankless and a gas tankless, honestly you shouldn't be selling them.
          • I have replaced many electric tankless water heaters that didn't even last 1 year. I have had to clean them every 3-6 months after they stopped heating the water in Mississippi where the water is very hard. I also replaced many electric tankless in NW Indiana before they lasted 1 year. I have had problems with the ones in Germany also.They seam to do better in the Florida panhandle but I would never recommend or use an electronic. I have yet to work on a gas on demand tankless but there are not very many in the areas I have plumbed.
            • Tim, what was the amperage demand for those electric tankless? i would think nothing short of twin 60 amp breakers per tank, with 3 tank minimum.
              Rick.
              • Sorry I don't remember exactly but the heaters were tiny and the plug and cord were huge. Most of them were supplying hot water to 1-3 lavatories and a few of them were bigger and supplied 2 big bathrooms.
