Recycled materials ?
  • Recycled materials ?
    This guy had to move his washer to put down a new floor and the valves were leaking , every thing else worked fine
    Very creative in the use of mat, i cant figure out what the pipe in the old vent was all about
    Re: Recycled materials ?
    Beautiful. That should be in an art museum not hidden in a wall.
      i would of used a dr pepper can and not a coke can.
      traps are overrated.
      i can honestly say, my customers are not that artistic.
        Is that an old Bubble Up bottle? It appears to fit the no hub coupling quite well. Who knew!
        Thanks for the pics!
          Finally a use for my old Ronco bottle and glass cutter making hose to pipe adapters
            Looks like some of the slumlord plumbing I run into; and they ask, "can't you just fix the leaky part?"
              I don't know what to say
              Maybe the guy was drunk while watching an episode of MacGyver and was inspired
              This is some of the best hack work I have seen yet!
              Rod
              http://unclognh.com
                Pictures of hack work alone don't really make me laugh or smile, lets see a before and after... If you didn't fix this, then I'm disappointed.
                  Unfortunately when you go a mile out of town some plumbing is not up to par.... I am not the enforcer what home owners do is there own business
                  Side note this guy is a good electrician but obviously not a plumber
                    That is a trophy
                      I need to stock a couple of those 1/16 bend ferncos on the truck.
                        I just want to say Thank You to all the hacks that get er done
