Washing machine valves
  • Washing machine valves
    I'm almost out of the washing machine valves that I like to use, and I found out that the company no longer makes the style I liked. I was using this style valve from the IPS corporation,
    because I could either install it in a washer box that was already in place, or unscrew the top of the valve and screw it into a FIP adapter if I needed to.
    The new valves they make are a rough brass that the top doesn't unscrew, which means I'd have to carry more styles of valves on the truck.
    Does any company make a valve that is similar to the one in the picture?
    Re: Washing machine valves
    Try Oatey
      Sioux Chief
        my vote is oatey as well...looks alot like em...
        Derek
          Those valves are defective in my state, and the stems snap off and cause 1000's in damage to my customers homes.
          I called out the rep on this at a convention, me and 2 other plumbers took him out back and rearranged his future.
          He then admitted to the defect and stated the changes were made to solve the issue.
          That stem for some reason is flattened like a blade inside of the valve, and when calcium builds up it will cause a failure, handle flys off and it's below the embedded O-ring on the stem, the 0-ring that's keeping the water from coming through.
          The above picture is the fix for those defective valves, and I remove about 25 sets of those a year.
          Pay attention to the date on that approval sticker in that washer box. 2004.
          7 years and they snap off in the customer's hands.
            I actually know the Engineer from Oatey who holds the patent on the laundry boxes. When we were having problems with a project that had Oatey boxes I made a call to Ohio and he was on a plane in a matter of days.
              Here are some made by Oatey.
              http://www.hardwareworld.com/14turn-...e-pN7NTA5.aspx
              I usually stub down through the box leaving a 1/2 FIP adapter in the box to screw a boiler drain into. Easy future replcements without wall cutting.
                There are thousands of those valves installed in my town out here (many of them by me), and I have never seen a problem with them like in your picture. I'm not saying it didn't happen, just that I have never seen it.
                  Aaannndd.....What???
                    I run 1/2" into the box and throw away the valves that come with it.
                    Ask Rookie Plumber,just did one at his old neighbors house.
                      We had a bunch here do it in homes without water softeners...don't think its a coincidence but?????
                      Derek
                        Thanks all. I was not aware of this problem.
                          That's one of the big reasons I like those shut off valves. These valves have the FIP adapter built into them, so you can do a replacement without opening the wall.
                            So you can do quick replacements by robbing the top part of the valve? if your installing new box you can buy jjust the box with the rubber gommets an then use fip adapters insdie the box then screw in a boiler drain.
                              No, I almost never have to replace a washing machine box. I can replace the bibs down the line without having to open the wall.
