What's wrong with this flange?
  • What's wrong with this flange?
    I pulled a toilet for replacement today and found this.
    I am standing in front of the flange as I take the picture.
    What's wrong?
    Re: What's wrong with this flange?
    What's wrong?
    Must...work....on.....psychic.....abilities......
      Oops. Too quick to hit reply. Here is the pic.
        I'm gonna' assume the screws are there on the left side.
        Below floor level and turned to let the bolts slip?
          Below floor level?
          Yes, that's one big p.i.t.a. problem. But not the biggest (methinks).
            Did you edit before I could reply J.C.? I guess that's why you have like 8 times the posts I do. (by the way, I just noticed I passed 1000 this week, WOOT!)
            Yes, That's it. I couldn't believe they turned the flange so the bolts wouldn't slide secure. They caulked the toilet to the floor so it wouldn't move.
              I have seen that a lot of times.... you just gotta laugh
              Seattle Drain Service
                look at JC's post count compared to mine and we almost joined at the same time. Keyboard w h or
                  The toilet bolt slots are misaligned.
                  I shake my head every single time when I see a flange set with using those toilet bowl holes.
                    Yeah, I'm pretty fast with the keys. If I could only find some $$$$ use for it.
                      I dont know who did it but I'ma blame a tile guy They make more problems they solve.
                      I'm on a big remodel and the tile guy decided to "help" remove a couple pvc flanges. Things did not go well for mr hackster.
                        I knew the tile guy was gonna get the blame...only because I was gonna blame him too....fender washers to the rescue!!!!
                        Derek
                          Or if the flange is low enough you could use a pvc spacer flange on top of that one, spin it so the bolt holes line up..Or cut it out ..Just hope the fender washers don't pull on the sides and break..
                            That is all too common on a lot of the jobs i see. Flooring contracrors are always putting in new sub-floors then tile on top causing the flange( which usually needs replacing anyway) to sit too low.
                            Worse, they are often watched over by a general contractor who should know enough to get a plumber involved, but seldom does.
                            Then we get the call to set the fixture cause the contractor cant get it to work. Ends up costing him more in the long run and it serves him right!!
                              It by no means is easy to get a big set under the pvc with your closet bolt then I put another washer on top of that with a nut then wax then bowl...etc etc...but u guys probably already know this...but now if its on a wood floor then thats a different story...
                              Derek
