Cut off saws ?
  • Cut off saws ?
    Looking for a good cut off saw to use in ditches for cutting cast iron pipe for repairs ..Probably a 14" blade to go through 4" cast iron..Should I look for diamond tipped blades or the abrasive cutoff wheels..The diamonds I'm sure will be costly but the abrasives will wear down to nothing probably quickly..Any suggestions on saw brands and cutting blade combos..Thanks
    Re: Cut off saws ?
    In my experience the abrasives have been more cost effective. They do wear down but the diamonds IMHO in this application dont last long enough to make the increased cost worth it.
      Re: Cut off saws ?
      a 14'' gas saw is your best bet as the electric ones tend to trip breakers when loaded up. plus the gas unit will cut concrete to 4'' thick without an issue.
      new saws run from $700-1200.
      now if you want a concrete gas chainsaw, i'll sell you a brand new one with diamond chain for $1000. that's approx $500 off it's going price. will cut 12'' deep and scuare corners. no overcut.
        Re: Cut off saws ?
        we have a Stihl gas saw and we use the abrasive blades for black pipe and we have a diamond tipped blades for block
        i love it
          Re: Cut off saws ?
          http://www.youtube.com/watch?v=HgbNut7I0yU
          Bar None
            Re: Cut off saws ?
            Another vote for Stihl gas cutoff saw.
            I had to rent one..one time because a backhoe drive cracked a sewer line when we were installing a new water service. I swear that saw cut through that cast iron within seconds.
              Re: Cut off saws ?
              Texas chainsaw massacre guy could have used this!
                Re: Cut off saws ?
                Originally posted by gobby View Post
                I bet ..Anything hilti is big bucks ..Have never bought anything hilti..could never afford it..I bet that saw is atleast $2,000.00
                  Re: Cut off saws ?
                  There is a brand new one on e-bay for $1,075.00 (buy it now) with $83.33 for shipping.
                    Re: Cut off saws ?
                    100% Stihl saw.
                    Dolmar, wacker, makita and another brand are all the same saw and total junk IMO.
                    I was very anal about blowing out filters and having proper mix and I blew up so many of those saws, it's sad.
                    I even had a 1/2hr conversation with a Dolmar engineer and followed his instructions to a T with a brand new saw and I blew it up in about a month, not even 20hrs of run time.
                    I finely convinced the boss to spend the extra on a Stihl. That was over six years ago and they are still using it today.
                    Blow out the filter every morning and a stihl will last forever.
                    Stihls are safer as they cut with lower RPMs and relie more on torque/power to cut as opposed to most other saws that use higher RPM's and less torque/power.
                    Husqvarna is also a reliable saw, but way to under powered and they vibrate too much. Hard on the hands for any long term cutting.
                      Re: Cut off saws ?
                      I have a 14" hilti gas saw carborundum for C.I. Diamond for terra cotta ,or concrete. I buy the diamond with the heavy lugs on the rim at H.D. DMD. blades are to pricy to wear out early on C.I.I always use water with dmd. blade and dry on carb. ones. Sure is a slick way to work!
                        Re: Cut off saws ?
                        Thanks all, I ended up borrowing one for my weekend project..I was surprised it ran..It was only a 12" stihl.I could not get the saw around the 4" cast iron as the water service was right on top of it (of course)..So I did a plunge cut and finished it off with my angle grinder with abrasive cut off wheel.That little grinder saved me again and allowed me to grind down all the nodules all over both ends of the pipe for tieing onto..I am going to start looking for a 14" model..Thanks again for all the input.
                          Re: Cut off saws ?
                          I have a 14" chainsaw style saw like Rick and it needs a lot smaller hole to access the pipe then a 14" circular saw does, if his is a ICS model a grand with chain is a good deal. I am looking for a hydraulic version now.
                          Seattle Drain Service
                            Re: Cut off saws ?
                            ics brand new with brand new chain and bar.
                            cuda, do you already have a hydraulic power pack?
                              Re: Cut off saws ?
                              Diamond blade or not..Do you guys really rip into pipe with those things? That has to make one gnarly cut even with a diamond chain..I'll probably stick with the cut off saw 14" ..when I find a deal
                              http://cgi.ebay.com/HILTI-DSH-900-Ga...item4cf52c64bb I am seriously thinking about this one
