Regarding Residential Fire Sprinklers
  • Regarding Residential Fire Sprinklers
    What sets them off? Heat? Smoke? Where are the sensors, in the sprinkler heads themselves?
    Would say, soldering nearby (3 ft.) and the smoke or heat from that set them off?
    If so, is there a way to temporarily shut it down? Or should the sensor be covered somehow?
    Inquiring plumber minds want to know.
    Re: Regarding Residential Fire Sprinklers
    I believe it is Heat/Vial.
    Shouldn't set it off.
    Cover if you're scared.
    Have a couple of small wood wedges ready.
      Sorry, you said Residential. No experience there. It may be something totally different.
        They will activate if they reach a certain temperature. Not sure how hot it has to be, but they will activate individually. The sensor is in the head if it is a wet sprinkler system. Like JC said you can keep some small wooden wedges handy. Push them in from opposite sides for a quick shutoff. In CT, homes with a sprinkler system have a second dedicated water line just for the sprinklers. Know where it is before you start so you can turn it off in an emergency. Sorry. I know this is the plumbing pro section. I’M NOT A PLUMBER. I’m speaking from 13 years in the fire service.
          Next time that your near one look at the head,lot's of them have the temp. stamped on them,heads need heat to go off,if one pops it won't make the others in the building go off unless they recieve heat in excess of the heads rating.Had an app. set one off years back doing a water heater in a closet w/a head above him,he got a good bath.If I think there's a chance of one popping I wrap it with a good thick towel for a little piece of mind.Commercial "smoke detectors" can be shut down or they make a small plastic cover that you can snap on it to seal it off temporarily.
          Steve in the trade since 73 doing new residential/Commercial work
            I know hitting them with a fork lift will set them off and accidently hitting them with a torch will set them off.
            Other than that, I have no idea
              Fire sprinklers, both residential and commercial, are individually activated by heat. There is an exception to this, called a deluge system, but deluge systems are not very common in commercial/industrial, and I cant think of an instance where they would be practical for residential use.
              The most common sprinklers used today are the quick response, glass bulb type, though fusible link heads are still manufactured. The majority of the sprinklers you will run across in a residential setting will be a red glass bulb, which is a 155* sprinkler.
              The glass bulb sprinklers have a bulb filled with liquid, and a small bubble in the liquid. The size of the bubble determines the temp rating of the sprinkler. Temp rating for glass bulb sprinklers is identified by the color of the liquid in the bulb. Fusible link sprinklers have an alloy, similar to solder, that melts at varying temps, releasing the metal link that holds the pip cap in place. Temp rating of fusible alloy sprinklers is identified by the color painted on the sprinkler frame.
              I would avoid sources of heat in close proximity to a sprinkler head. If it's unavoidable, I would use some sort of heat resistant material to shield the sprinkler and try to keep as much heat as possible away from the head (having a helper hold a five gallon bucket over the head, tight against the ceiling should work fine). If you cover the sprinkler, use care since they are fairly fragile. You can shutdown and drain the sprinkler system as a precaution. Remember to restore the system to operation by removing any covers, or heat shielding, and opening all the correct valves.
                LOL...No it was a skyjacker I was using...quit following me around!!
                Derek
                  Thanks everyone (especially bml)! I am now well educated.
                  (though i already knew not to drive a forklift in the house)
