Snug fit?
  • Snug fit?
    In trying to clean up someone else's mess, I'm looking into the feasibility of putting a 3" PVC hub clean out fitting inside a piece of 4" pipe. Anyone know if it will make a snug fit? I seem to recall that someone used to make a fitting specifically for that purpose.
    Re: Snug fit?
    A 3" hub will fit inside a piece of 4" pipe ..I would try something else though..
      Re: Snug fit?
      I'd like to try a Sioux Chief cleanout bushing (875-4P) but no one close by stocks them.
      http://www.siouxchief.com/Drainage/C...-Bushing.HXJIP
        Re: Snug fit?
        Get a 4x3 flange and cut the spigot off. It will glue inside 4" pipe and a 3" male c.O. will glue inside of it.
          Re: Snug fit?
          Duct tape
            Re: Snug fit?
            My supply house has called them "Tom Kap"
              Re: Snug fit?
              Every new construction plumber out here uses those Tom Kaps for clean outs. They shrink the opening of the pipe by a 1/2", limiting what you can send down the line when it's time to snake it.
                Re: Snug fit?
                the tom kap is also sold at home depot. the opening is slightly smaller than the pipe. blades will easily flex into the 2'' deep insert and spring back open. the nice thing in the ability to cut them off flush to grade after a pour.
                  Re: Snug fit?
                  Try looking for the 875-845 C/O bushing kit,sometimes easier to find.
                  Steve in the trade since 73 doing new residential/Commercial work
                    Re: Snug fit?
                    I've had multiple page lectures from online plumbers..yes online plumbers I call them.......about using 4x3 closet flanges solvent welded inside 4" pvc. Now links are being posted for c.o's that solvent weld inside of pipe and alls good.
                    So my question is....Where are all the codebook thumpers hiding?
                      Re: Snug fit?
                      Never heard of a Tom Cap
                        Re: Snug fit?
                        It's a clean out adapter that glues inside of the pipe. see them used a lot when the plumber doesn't cut the risers off at the right height, and concrete gets poured right up to the pipe.
                          Re: Snug fit?
                          Some seem to think if you hafta solvent weld a fitting inside the pipe you should just jackhammer the floor up and "do it right".
                          Basically thay dont believe you should glue anything inside a pipe.
                          Here have a read on this thread. Read page 8,9,10 and 11 of this thread.
                          http://www.ridgidforum.com/forum/sho...nge#post325569
                            Re: Snug fit?
                            I don't mind it so much on schedule 40, but I can't make myself think it's any shade of correct on cellular core. That said, It may outlast the building it's put in, only time will tell.
                              Re: Snug fit?
                              Nobody's gonna bite...... awwwwwww
