Aquasource T & S diverter problem
  • Aquasource T & S diverter problem
    Customer has a fairly new (2 mos.) Aquasource (Global Industrial, danze, pegasus, etc, etc.) tub and shower faucet that diverts water to the shower slightly when running the tub only. It has a diverter spout.
    This is a new customer who had her bathroom remodeled by H. & S. Inc.(Hack & Slash). The faucet is connected entirely with shark bite fittings.
    Do you think the shark bite on the spout nipple is causing enough restriction to divert the water to the shower slightly?
    Re: Aquasource T & S diverter problem
    I would say something could be wrong with the spout itself.
      I honestly dont know what to say about that, other than thats like $100 in sharkbites alone!
        Isn't that valve in sideways?
        Thanks.
          When I go back I intend to replace the spout just to see. I was there repairing other f.ups when she mentioned this faucet.
          She was wondering why the tub wouldn't hold water. H & S removed the linkage from the trip lever waste and overflow for some reason.
            Thanks.
            Here's the front pic. I couldn't find an "up" or "down" on the valve. It could be on the front of the valve but the r.i. plate is still on it. The writing is sideways.
            But, the integral cutoffs are correct.
              1st off I would rip all that out or wouldn't touch any of it. The problem is the 1/2 cpvc between the valve and the sharkbite drop ell. Its I.d. is smaller. The cpvc being there is enough to make the shower dribble.
                Tim, you call them hack and slash but this quality work is all too common these days, even among licensed plumbers.
                  I want to tell you to take it all out and start over.
                  You may be able to replace the tub drop and make it work. There is a certain distance minimum for most valves. And make sure H&S hasn't threaded the spout on so far that it's against the diverter gate.
                  Good luck.
                    I wish I had the pictures to show you what they did with the tub strainer. Apparently they had moved the tub somewhat and the 1 x 8 subfloor (this is conventional foundation) beneath the tub covered at least a quarter of the space beneath the strainer hole. I have no idea how they were able to start the threads on the strainer.
                    These people have no $$$ at the moment. It will be a simple thing to replace the diverter spout. If that doesn't do it then I will reassess.
                    T.M. My search says 1/2" cpvc has an i.d. of .622 while L copper only has a i.d. of .545
                      cpvc has a smaller I.D. than copper. The O.d is the same and cpvc has a thicker pipe wall than L copper. Go measure some.
                        Slimtim:
                        If I were you I would remove the tub spout, leaving the nipple in place. Fill the tub. If the shower stops dribbling try using a different diverter tub spout. If not, it may be that the quality valve (is it even anti scald?) doesn't have internal porting designed to eliminate the shower dribble. In that case you may have to install a twin ell at the tub spout and reconnect to the shower off that.
                        That's some really nice work.
                          You sure the valve is not upside down?
                            chances are they left the tube stiffeners in the sharkbite fittings that are designed for pex tubing. these will reduce the id of the pipe at both the inlet and outlet to the tub drop. remove the stiffeners and try or replace the drop pipe.
                            best bet is to swap out the cpvc/ sharkbite with a copper mip and drop el 90, or brass nipple and 90.
                            if the valve and trim came with the diverter spout, then no twin el is required.
                              Looks like one of our local HVAC guys when they get slow ...personally I would take it out..put in a delta..and for the love of pete...use copper...man somebody should have a little pride in their work...(sorry been looking at bad installs and redoing all the plumbing both water and drainage in a 500,000 home thats only 2 years old... i'm a bit cranky this morning)
                              Derek
