Hot Repipe With Pex
    Re: Hot Repipe With Pex
    Originally posted by Flux View Post
    I understand things are done much different down south, but why use a material that would require that many joints in the first place?
    A 200' or 400' roll of Black Poly pipe would be a much better installation for water services, then a material using glue joints.
    Just my opinion.
    I dare say 90%+ of 1" or less is done exactly as you describe in this part of the South.
    EDIT: And not uncommon to have a box at both ends/connections.
      Just my opinion.
      Mine 2
        Most water services in the south from the meter to the house is bell end sch 40 20' sticks IMO
          I haven't worked in as many areas of the South as some. Almost none here are ever done that way. I can't even remember the last one I've seen.
          Sidenote: I had to work on a submersible well pump today that was piped with thin wall PVC & just wanted to find whoever did it and whip them with it.
            Why.. If there is a way to run a water service eliminating joints except at the beginning and end ..Here we go again
              Pvc has been used since the early 70's here...alot of homes have it and its about 40 years old...and its still in service. I guess thats why.
                So in other words cause' that's just the way it's been done ..Doesn't matter that there are better materials out there now..
                The more things change the more they stay the same
                • #23
                  No in other words its a time proven material. And its cheap and its easy to install and if thats what people want to use its ok with me.
                  • #24
                    Ok..Would you say Pex is a time proven material ?
                    • #25
                      Yes its a great product if its installed properly.
                      • #26
                        PVC is ran occasionally here when it gets to 1.5" or better. Works just fine to my knowledge. (Schedule 40 heavier wall)
                        Smaller lines it seems PE is better with less joints. (Thicker wall 160psi).
                        Both can have their place I guess.
                        • #27
                          Does anyone really know what the life expectancy of a pvc glue joint is?
                          • #28
                            I have no idea. Never read any long term tests.
                            All glue joints are characterized to be a "solvent weld" to my knowledge.
                            I think that's defined as the two parts becoming one when done correctly.
                            (I know, I know, I've seen the things pulled apart, blown apart, etc. just as many others have. )
                            • #29
                              I helped install some sch 40 pvc natural gas line 28 years ago......its still in service.
                              Also I occasinally find 3/8 o.d. polybutylene flared and ran for gas lines undergound to post mounted gaslights.
                              • #30
                                But those were heat fusion welds right? Or are you talking a solvent weld glue joint?
