Swing check or spring check valve?
  • Swing check or spring check valve?
    On a recirculating system is one better than the other? I'm thinking, spring check valve. Water heaters are bottom fed. Hot outlet on top.
    Re: Swing check or spring check valve?
    spring checks can be used in all positions and tend to hold much tighter. problem is they're more restrictive.
    i use wye pattern checks 99% of the time on 2'' and less. wafer checks on the big stuff.
      Bingo!
        I'll second that bingo!!!
        Derek
          Spring check valves are also susceptible to mineral buildup failure.
            And... more than once I've removed a failed spring check that had solder stuck in it in such a way that it wouldn't close.
              Swing checks for me.
                i install swing checks(horizontal only) spring if on verticial ,but have replaced alot of spring check due to build up holding it open causing "luke warm water"
                  Swing checks, or Teflon ball checks. Just make sure you put em' in the right way
                    swing checks.
                      Swing
                        What ever works best. Also what the supply house has available, they routinely run out of copper, copper fittings, hangers, ball valves, drainage fittings, you name it, they'll run short.
                          Thanks for the replies. I ordered spring check valves ( 1 1/2" ) but you guys are swaying me to order swing checks.
                            Indeed, you are wise beyond your years.
