Concrete fire collars
  • Concrete fire collars
    Looking for sleeves to put through core drilled holes.We are piping through concrete core drilled holes and probably will have to fire stop.Last build out we did we used pvc pipe and fire rated caulk.But I prefer to drill a hole and insert a fire sleeve , fasten that to the slab, then run pipe through the sleeve. Looking for a source and pricing..Thanks
    Re: Concrete fire collars
    We mostly use Hilton products but I prefer Proset
    http://www.openfos.com/supply/Proset...restopping.htm
      we make our own we have our sheet metal shop weld a flat plate on some round heavy sheet metal and we put one in from one side and the one from the other side is a little smaller so it goes in side the other round sleeve . then fire caulk every thing after the pipe is in .
      thats for black and copper pipe for PVC we use 3 M fire rings that will close the hole after the pipe melts
        Thanks guys ..probably will be needin' a few..
