Tankless descaler pump choice
  • Tankless descaler pump choice
    https://app.qleapahead.com/rtp/libra...sset=109578,63
    Looking at the 44 Model to descale tankless water heaters. Any opinions on anything better?
    Re: Tankless descaler pump choice
    that's the one i'm using
    a transfer pump is also a good choice if you can easily prime it or is self priming.
      Just using straight vinegar or is something better?
        http://www.flow-aide.com
        I like this system. If you wanted to build your own system, I would still recommend using Flow-aide. We have been using for a year now. It's amazing how clean it gets the exchanger.
        "don't put that in your mouth, you don't know where it's been"
          How much does the descaler liquid set you back? Just bought the pump.
            A gallon is around $50.00. I usually get 4-8 tankless out one gallon, but the rep for flowaide, said that you can do more. I guess I'm a little heavy handed. I also built my own system, but am going to buy there whole setup for $149.00 including the pump and one gallon the next time I have to do one. Ferguson enterprises should be able to get the stuff for you. It is a little pricey, but I think it beats the vinegar solution.
              i'm 99% sure clr/ calcium lime rust remover is approved for use in tankless heaters.
              i still use white vinegar. pretty cheap at costco and smart and final.
