K50 with A-17 adapter
  • K50 with A-17 adapter
    What do you guys recommend as far as a replacement cable for the A-17 adapter? 5/16 or 3/8 ? IC or not IC? bulb or no bulb? Where do you use this setup the most?
    Re: K50 with A-17 adapter
    A runs 5/16"
    B runs 3/8"
    So your choice would be based on your drum
    I use B, with 35' bulb.
    'tubs.
    I only put on the drum when the 5/8" will not work.
      do you know if 25' of the 5/16 is the max length for the A-17 or can you use a 35'?
        it's actually 50' a-17 when ordered as a, d or e option. d and e were just longer cables as standard option.
          I'm guessing that nozzle stays the same no matter what cable you've got in there.
          50' of 5/16
          35' of 3/8
          I already have C-1 in my 39. So I'm leaning towards C-6.
            the front brass guide for the cable is a differnt size for the 5/16'' and the 3/8''. it's what grip the cable tight.
