Crane WC ques.
  • Crane WC ques.
    Crane floor mount/rear discharge tank type WC ADA height,6 story bldg.,4" stack,2 WC per floor on the stack.Do you need a 4" collar or will a 3" collar work(limited space in the wall,they will not fatten the wall),Illinois code/isometric plan drawings don't specifically address it.The stack will be suspended under the chase/wall for 2 side by side baths with a combo on it's back coming up behind each WC with a pick up for a lav off the end of the run and a 2nd lav off the stack above the floor,tubs/showers are on a separate stack,share your thoughts.
    Steve in the trade since 73 doing new residential/Commercial work
    Re: Crane WC ques.
    The Crane site doesn't show a floor set rear outlet WC. Do you have a model # ?
    I've installed a few floor set WCs (I think primarily AM Stan) they would accept any normal closet flange.
      Re: Crane WC ques.
      Gerber accepts a normal flange as well.
