Liberty sewage pump
  • Liberty sewage pump
    Guys gotta install a liberty 380 pro series sewage pump and pit.
    It is tank and pump combo deal,It has a 4/10 hp motor,Has any one installed these before,And are they any good for a bathroom,Cheers guys.
    Re: Liberty sewage pump
    Yep, good stuff. Install a lot of Liberty pumps
      Thank you for the quick responce,Can they handle a bathtub ok,And I take it they are dependable,With your reply.
      Thanks again,
        Me personally, I would never install a 4/10 hp sewage ejector pump.
        4/10 hp = a mistake imo.
        1/2 hp - is perfect for your situation.
        3/4 hp - might be a bit much
        1 hp - you're kicking a$$
        1 1/2 hp - you will have enough power to throw $hit across yours and your neighbor's property.
          Thank you,From the bottom of the 2ft pit to where it ties in is no more than 10 ft almost straight up,
          With practically no horizontal run,
          So you reckon that the liberty 4/10 hp is not enough then,Cheers for your input.
            I probably shouldn't of used the word "mistake" when it comes to the 4/10 hp pump. I'm sure it's adequate enough to do what you want to do there. I think a better use of words should of been " bottom of the line pump". It's just personal preference and nothing more.
            Think of it like this..
            People complain all the time that a 1/3 hp garbage disposal is crap and doesn't grind or have the power of a 1/2 hp garbage disposal and above.
            If someone wants us to install a sewer ejector system, I'm going to give them a better pump is all. I'm not going to throw in the bottom of the line pump just to put more money in my pocket.
              Thanks again the horse power seems good enough tho right,Just a poor pump then,How about a myers pump ,Not a pump expert thank you
                I'm not saying it's a "poor pump" as in name brand. I'm just saying I don't like using 4/10 hp pumps by any manufacture.
                Pump wise, you can't go wrong with..
                - Liberty
                - Zoeller
                - Hydromatic
                - Myers
                Some guys like "little giant" pumps, but I'm always afraid to use them on Sewage pits.
                  HP in pumps has more to do with how high the lift is. in 95% of residential situations a 4/10 hp pump will work fine. A 1/2 hp is not that much better. I have installed many 4/10 hp Hydromatic, and Liberty pumps with out any complaints.
                  To the OP the system you are installing is a great setup. It will handle everything you need for your application.
                    You're partially correct, but in this instance the impeller is much better on the 1/2 hp versus the 4/10, and that's just as important as the lift. One is corrosion resistant and the other is not.
                    There is about a $40.00 difference in price between both models.
                      Thanks again but I dont think there is a 1/2 hp in this combo outfit,
                      Ill shop around,Thanks for input,
                        There is.. here is the model number for that package. P382LE51
                          Just installed a 370 series with 1hp motor. I love it all in one system plus liberty made it super easy to lift out the pump. My wholesaler showed me this one and I was sold instantly! Great system and great price (even with the air freight )
                          Ray
                          www.mauiplumbinginc.com
                            I always like to put a high level alarm on these systems. I will pay for its self if the pump ever fails. Liberty makes a quality pump.
                              Plus one on a high level alarm, it will save you much grief if the pump ever "craps out"
