2.5" black iron
  • 2.5" black iron
    I am putting a proposal together for a 2.5" black iron NG 5psi pipe. I've not done a gas line this large and in talking with the inspector he said that the preferred joining method is welding but threading (my plan) is fine as long as pressure test passes. This makes me question my plan...
    Should, in your opinion, this pipe be welded? If so - why? What is the problem with threading this pipe vs welding?
    Thanks
    Re: 2.5" black iron
    welding would require a plumber/ fitter that's a certified welder.
    screw pipe would require a 141 or similar machine to thread the pipe.
    anything over 4'' ips, we welded. wrenching 2.5'' is not that difficult, especially with a compound leverage wrench
    personally, screw pipe would be less expensive as you don't need the certified welder$$.
      Re: 2.5" black iron
      That is what I was thinking. I would have to pass on the job if it had to be welded, but I don't see why it would be. Thanks for the vindication. Time to get that threader warmed up.
      I talked to the inspector because the CBC says that over 4" ips has to be welded but it is up to the AHJ for less than 4.
        Re: 2.5" black iron
        Any certified (qualified) welder can do the job for you, in MA the plumber "supervises" the subcontracted trade.
          Re: 2.5" black iron
          we thread up to and including 4" here, unless an engineer specifies otherwise.
            Re: 2.5" black iron
            I'll do the roots with 6010 , You can do the covers with 7018.
            red eye leaves Boston 1;00 am bring Your 6 G papers. Tool
              Re: 2.5" black iron
              I did a 2" B. I. MED. gas pipe in L.A. About
              15 years ago had no problem passing test All threaded pipe and fittings
              I tested at 30psi, before i called for the
              inspector
              PS IN L.A. YOU HAVE TO PUT THOSE STICKY PIPE LABELS EVERY SO MANY FEET SAY MEDIUM PRESSURE GAS
              JERRYMAC
              E-MAILJERRYMAC777@GMAIL.COM
              FIRE SPRINKLER CONTRACTOR,
              SINCE JAN. 1989
                Re: 2.5" black iron
                Ah just run a dozen 1" gastite lines over to a manifold and be done with it
                  Re: 2.5" black iron
                  Ok here is your rig
                    Re: 2.5" black iron
                    we weld every thing 2 1/2 and over it is much faster then threading it
                      Re: 2.5" black iron
                      then you've never seen me cut, ream and thread by hand
                        Re: 2.5" black iron
                        Ok here is your rig
                        Nice set up . welds soo smooth , sounds soo smooth.
                        Was on the cape 2 weeks ago. Love those fried clams. too cold for
                        me anymore. statey clocked Me doing 80 in the underground in Boston. Let Me go, No ticket! Another Irishman, Bless Him !
