Moen Diverter with Posi Temp Cartridge
    Re: Moen Diverter with Posi Temp Cartridge
    I would bet it's the handheld. I fought a Moen once and lost, 4 cartridge replacements later, I realized it was all the water in the handheld hose.
      Bogart thanks so much. I am having homeowner do a test. Question? Why only this handheld. Have installed many positemps with handheld and no issues. He bought the handheld from Depot. Again thanks so much.
      The Plumber/Firefighter
        This whole thread amazes me. You guys jokin around or what? The 1st thing that should have been done after a suspected leak would be to remove the handheld. Thats plumbing 101 1st day type stuff.
          Master believe me it's all about being polite. I am very aware ! Was looking for something more specific but when u ask a question u give everyone a chance so give it a break unless u know it all.
            I almost know it all.....but I want to ask one question. Does the handheld you installed have a vaccum breaker just below the shower arm or ell connection?
              I am pretty sharp myself. No vacumn breaker sir . The whole things baffles me.
                Well thats why its siphoning. The hoses that dont siphon have a vaccum breaker...or a leak A way for it to get air and break the siphon Very sharp indeed.
                • #23
                  Your wrong , with the shower head disconnected it still drips. Sharp huh !
                  • #24
                    Yes it will drip out of both ends.....the lower end will drip more. Very sharp
                    next time try removing the entire hose..not just the head.
                    • #25
                      I have hooked up many this way, with homeowners purchasing handhelds from Depot with no issues. Working with a Moen Rep now . Thanks for the help though .
                      • #26
                        Regular head is now installed , still drips. Handheld is removed. Same problem. Somethings cannot be explained, even the master does not know sometimes.
                        • #27
                          I know you know but just put a nipple on it and gauge it.
                          • #28
                            JC , could u explain a little more ? Thanks
                            • #29
                              I didn't read everything.
                              What is the exact setup you have in the tub/shower?
                              1 valve? Valve and diverter valve?
                              Thanks.
                              • #30
                                Thanks.
                                Look I understand what your saying and I dont even have the problem. Throw a gauge on it and see if it builds pressure...if it builds pressure you have a leak.
