Flowgaurd Gold CPVC
  • Flowgaurd Gold CPVC
    I'm looking for other plumbers that have experienced problems with CPVC piping when a compression type fixture stop is installed on the pipe. I have letters and documentation from the stop manufacturer that states their stops can be used on CPVC and they recognize this practice as industry standard in some areas of the country. Lubrizol (Flowgaurd Gold) also has public documentation that recognizes these types of connections as acceptable.
    I am experiencing failures at toilets, lavatories, kitchen sinks, etc. on the hot and cold side of the system where a fixture stop just breaks off obviously flooding the home. I have had several of these tested by a chemist to try and figure out what the issue is. The test results where somewhat inconclusive due to lubrizol's resin "recipe" not being public knowledge so the chemist had nothing to compare the ingredients to.
    Anyway, the failures I'm seeing are around 4-5 years after installation which is whithin the 8 year state statute that covers a homeowner against poor workmanship. I'm being sued on a regular basis for poor workmanship and I am convinced something is wrong with the pipe. I'm hoping I can find a few more companies that have experienced the same issue so we can get Lubrizol to discuss this.
    Re: Flowgaurd Gold CPVC
    Could you be a little more precise about the "compression type fixture stop"?
    Are you installing regular angle stops with a nut and ferrule on cpvc? Or are you talking about the push on shark bite types?
      Glue on a threaded adapter first, cheap and it works.
      8 yr statute? Must be something through the builder cause I've never seen a trade in these mass built homes come back and fix something even in the first year.
        It sounds like a Chemist was the wrong place to start with. What you needed was a Metallurgist who specializes in failure analysis first. He could have used a scanning electron microscope and told you what elements and in what percentage were present. Then if you believe it is a chemistry problem you already have the info.
          We install more Flowguard Gold CPVC than anything else.
          Copper used to be king, now it's not even specified
          for residential and light commercial.
          We commonly use regular compression stops and wrap the
          ferrule with a few laps of teflon tape to keep it centered
          and have had zero problems. Avoid over tightening.
          Also have used glue-on stops, which are more costly but
          easier to install. There's a long list of incompatible products
          that can't be used on FG Gold CPVC. Everything from certain pipe
          dopes to pesticides.
            I have installed thousands of compression stops with cpvc..I don't anymore.In my opinion the ferrules are cutting into the cpvc..Use the glue on valves.I have come back on them , like you say years later and found leaks at all the fixtures, rust all over the escucheons, etc.. Or like mentioned above an adapter that will work for the compression valve..Or maybe they should make a cpvc ferrule like they did for the old poly supply tubes
              Same thing here...re piped with Flowguard Gold CPVC no problems...wrapped telfon like Jim said and not overtighten....Makes you wonder what pesticides are doing around your plumbing....
              Derek
                I get a little worried every time i have to touch a plastic water pipe in side a house
                All my hair would be gray if i had to see it every day
                  Without exception, every problem I have seen in CPVC has been related to installation or mechanical issues. That said we have very little CPVC out here.
                    We had some Flowgaurd piping failures a few years back,Charlotte checked them for the shop and the findings were that a unidentifiable foreign substance on the joint caused the failure.They left it at that"not a manufacturer/installation problem".....................
                    Steve in the trade since 73 doing new residential/Commercial work
                      I don't know why anyone is surprised of these failures. A "hack" saw and a can of glue and you're a plumber.
                        Not sure about that..Cpvc has been around long enough to prove itself to me ..Iguess you are a "hack" if you install anything but copper ..What are your feelings about Pex
                          I believe the main concern is with termite treatment of the slab
                          if you're ground roughing with CPVC.
                            Oh...interesting...glad I was re piping and not new installs....
                            Derek
                              You need to post some pictures of these failures. The stop used and the break point. More than one if you can.
                              Might help.
                              P.S. The pipe company AND the stop company will do everything they can to declare it "poor workmanship". They'll look for a microdot of an unapproved pipe dope that was on your glove. Blame you for everything.
                              Sorry you're having to go through this.
