Seismic gas valves and bracing
  • Seismic gas valves and bracing
    As required i install a unistrut right angle brace to valve. Being a welder,I fab up my own in My shop. They are suppose to be within 6" of auto valve. I had P.G.&E REMOVE THE U clamp from their riser on one of mine. I had clamped to their riser at top. From now on I will clamp only to customers side. They rang the door bell and told customer installation was fine,and used a sniffer. I discovered the missing clamp today.
    I just learned what not to do and will correct tomorrow. Hope this helps out another member. Tool.
    Re: Seismic gas valves and bracing
    tool their side of the meter is a no no. customers side of the meter is free game.
      Thanks friend, just found this out!
      My sewers a no no also, P.G.&E
