Ram Bit Success Story!
  • Ram Bit Success Story!
    This is probably the 4th time I had to use one.. I had a 3x2 why on it's back don't ask how the 2" going into the wye leaked..but it did.I took the ram bit to it.I have an older craftsman 1/2" variable speed drill and was very careful to control the speed .I did stop short of the hub about 1/8" and plucked the last bit out with a tiny sharp screwdriver . after I cleaned the fitting real good I primed and glued the hell out of it.I was thinking the ram bit would make a loose sloppy fit but just the opposite..I had to hub that bad boy in with authority..Wham! And it held for the stack test..I am thinking the one I used was a Pasco..But I have also used the Raptor brand for a 3" fitting ..Any others have success using Ram Bits?
    Re: Ram Bit Success Story!
    Yes they work great. As advertised.
      Use them all the time. They work
        I also use them, and they do just as they claim.
          the ram bits do work. but they're slow and work by generating friction/ heat.
          if you want a real cutter that is fast and precision, the wheeler/ rex bits are the best.
