Inverter: I fried mine today.
  • Inverter: I fried mine today.
    This week I got myself a new Dewalt 10" compound Power Miter box. Today I decided to run it on the Aims 1500 watt pure sine wave inverter mounted in my truck.
    Pulled the trigger, the inverter popped off.
    Turned the inverter off, then on. Started the truck, flipped the switch so the backup battery was exposed to the main vehicle battery and alternator. I reasoned that a slightly higher voltage would result in lower amps feeding the inverter.
    Pulled the trigger, the inverter made a disagreeable arcing noise, a squeal, then an acrid pungent smell, along with smoke.
    If it doesn't rain tomorrow I'll pull it out and look at it. If it's toast as I suspect I think I'm going to get this one next.
    XTW3000-12 Pure Sine Power Bright Power Inverter 3000 watts
    This one should be big enough to run the suitcase welder, and any other power tools I have without blinking. I would welcome any suggestions regarding a superior brand or model inverter?
    Re: Inverter: I fried mine today.
    its dead, get a new one.
      sounds dead to me too but shouldn't it have some sort of overload protection to prevent this?
        Why yes it did. Apparently something went wrong. After I remove it from the truck I'm going to take the cover off and see if the problem is visible.
        Next time I'm getting a larger, more robust inverter to handle more of life's little surprises.
          For $800.00 how often do you use it I have a small inverter in the truck for cordless batteries and a honda 2000 generator that is supper quiet I use for jack hammers and my pipe threader if needed we also use it for camping to run tvs and other small devices that don't require the rvs big generator. I've had it for a few years and its saved me countless times recently I had AAA put my spare tire on my van on my way home on the freeway it turns out it was flat the tow truck driver had a little 2gal air tank that was empty so I used the generator to fired up my air compressor to air up the tire.
            Jholder: I find I use it sporadically. Although I did pretty much plumb a 16 unit office condo with the one that just died. The thing is when I need it, it's very handy. I did find that same unit at Amazon for $599. I'll probably order it tonight after I relax a bit. I have two generators I can put in the truck. A smallish 1500 watt Coleman, and a 5000 watt Honda. I greatly prefer the inverter as it's much quieter.
              I have no suggestions-I however have a question-What is the total finish install cost of such a project?
                Read the review. If it's correct, it says it will shutdown in temperatures of 95 degrees F. Not acceptable to me as it's position in a vehicle could get there easily even the outside temperature is much lower.
                  Which brings us to the inverter vs. generator topic. I am opting for a generator that is portable , doesn't take up much space in my truck (as there isn't much to spare) and can run what I need to run..
                    Once the magic smoke goes from an electrical device, it just won't work anymore. I decided to go with the honda eu2000 once I see them go on sale.
                      I'd be worried about hauling a generator around in the back of the truck with gasoline in it. knowing the way things get tossed in the back of the rig and how loads can shift while driving the generator could be upset and leak fuel. then you have another motor to maintain to boot.
                      You can get a underhood solution in one of two forms:
                      1. A small generator mounted under the hood that draws fuel from the vehicle fuel tank with start/stop controls on the dash.
                      2. A engine mounted belt-driven generator that can give you all the AC you need, with an optional welding capability too if
                      you had the need to do a little welding now and then.
                        After going through probably a dozen inverters over the years I have pretty much decided that they are all junk no matter how expensive they are. 5000 watt Honda.
                          What did it taste like?
                              Chicken of course.
                              BTW: I saw that 95 degree upper limit too and emailed some questions to other manufacturers regarding same. (They didn't specify upper limit value). Here in Minnesota the 95 degree's F wouldn't be a huge deal. But I would prefer an upper limit in the 100 F + range.
                              I also like the Aims 3000 watt inverter but the surge or overload is only 4500 watts whereas most of the others offer 6000 watt surge.
