Removing and replacing old w.h. Anoids
  • Removing and replacing old w.h. Anoids
    I would like a 3/4 drive torque multiplier and socket set up on truck.
    Any suggestions,and suppliers appreciated. thanks Tool
    Re: Removing and replacing old w.h. Anoids
    the harbor freight one is not bad and for the price you can't beat it.
    a 3/4'' electric impact will also do the trick much easier.
    i hope you're not planning on doing anode change outs. good luck.
      waterconnection.com
      $490. Well worth if you plan to remove more than one. I haven't found a better way.
      He has anode rods and drain ball valves with garden hose connections.
      My experience though is that water heater maintenance is a tough sell/payback/payoff for residential. but, for commercial it pays.
        I would suggest a impact wrench, 1/2" electric usually will work fine, much easier than trying to hold the tank from spinning,
        there are some automotive 1/2 drive torque multipliers, I Have seen for use on car lug nuts, my torque mu plier is a little larger,
        Northern Industrial Torque Multiplier Set | Torque Wrenches | Northern Tool + Equipment
        http://www.northerntool.com/shop/too...5001_200315001
        having some trouble with link hope one of them work,
          Great I have 2 elec impacts. I have an older 40 gal. reliance in our home. I just thought it would be a good idea to change out anode. NO ? THANKS Rick .
            [QUOTE=Mark7;347600]waterconnection.com
            My experience though is that water heater maintenance is a tough sell/payback/payoff for residential. but, for commercial it pays.[/QUOTE]
            exactly. hard enough to get them to flush/ drain a residential heater.
              here is another unit that may work and not extreamly bad price, for what it is, one would have to get the correct socket.
              Welcome To LugWrench.Biz
                Just used a socket and ratchet many times.
                  I think that in 35 years I may have changed two. I sell water heaters
                    Impact wrench on your anoids? Damn, that's gotta hurt.
                    Hope you use anesthesia first. I think I would prefer a scalpel.
                      I've only replaced 1 anode rod in in my 25 year career.
                        THAT'S NOT FUNNY! My 1 st wife did just that and stole our house. STUPID LITTLE BLOND NURSE COULDN'T KEEP HER PRETTY
                        LITTLE MOUTH SHUT !!!
                          I was wondering how long before someone jumped all over the spelling. Usually Mrs. Seatdown makes the correction. For the record I believe the word we are looking for in anode and the medical one would be adnoids
