Empty old w.h. Faster ?
    started a topic Empty old w.h. Faster ?
    Thinking, Plug one port , Using My Gas Pressure schrader valve set up,to blow it out with air compressor. proly read it here! Tanks impatient old fart.
    Re: Empty old w.h. Faster ?
    Originally posted by Big Jim View Post
    Thanks, Rainman, but I think we got it.
    I bet he's an excellent driver, too.
    When you takin' him to Vegas?
    I'm ready, ain't gonna miss a chance to Hang with You all.
  • Big Jim
    it's early for tool. so i'll translate
    tool got in trouble from the wife. he found a harbor freight 25miles away and is happy
    here's where it gets interesting
    my 2 brothers would be adam and i the sister is the matching pump we have.
    comes home to his wife asking what's inside
    it's not the red pump shoes for your closet shoe rack
    tool talk.
    Well I took the Harbor Freight pump and tried again tonight. Wash Machine hose in 5 gal bucket of water. [ Inlet port ] dribbles out only .pump was primed. I'll just get My $ back
  • shock1964
    This is the same pump I use, and it is awesome!! We use it for pumping boiler chemicals also. Great pump.
    Originally posted by SewerRatz View Post
    This is the pump I use the Liberty utility pump Liberty Pumps : Utility Pumps works grat for the last few years I had it.
    geno, i don't believe they have anything more than a heavy mesh screen. but they dam near strip search you before you get suited up. they have lockers that you store all your stuff in and they keep the key till you're done.
    this is a newer design with the fans up in the ceiling and they suck the air, then recirculate and blow it down and around. anything falls below and it pretty much stays below.
    the old original design from vegas around 27 years ago was the prop from an airplane was below you. anything falling into it and it explodes.
    the universal studio one is all clear acrylic and everyone can watch. if i'm not mistaking it's 4 fans generating 800 hp. in a 10' diameter x 30' tall tube. here is a link to all the indoor centers in the world. SkyVentureCorporate Website - Tunnel Locations
    iflyhollwood is the one at universal studios. not cheap, but lots of fun.
  • geno gardner
    i will gather up the crew and even take a shower.
    glendale puts you in a good location for all of us. maybe we can go indoor skydiving at universal since it's around the corner.
    lets keep in touch and plan on a big day o fun.
    indoor skydiving? That must be one tall building. LOL.
    I used to collect vibration data on axial fans and would have to be in the air stream occasionally. OMG! I used to sweat being hit by a foreign object in the airstream which was some ridiculous speed.
    Do you know if they have filter racks inline to protect the users?
  • Flux
    We pump out every single water heater.
  • SewerRatz
    Originally posted by ironranger View Post
    In all my time I've never once had to pump out a water heater. Blow out the sediment with the house pressure and let her go. By the time I'm set up with the new one it's empty.
    Only time I use the pump is second floor installs where there is no near by floor drain. Run the pump hose outside and let it rip. Ones with proper floor drains I just do as you do blow it out and then let it drain while I set up.
  • ironranger
  • Flux
    The Wayne's have a plastic impeller inside, at least mine does.
    Have had mine for 10 years now, without replacing impeller.
    at a 10' lift this little bugger pumps 300 gallons an hr.
    Imo..it's a solid back-up pump for water heaters.
    Originally posted by idlplumb View Post
    How about one of these?
    Sure it's cheap and not a quality brand, but chances are sediment from an old heater will destroy the impeller after a dozen or so uses anyway, right?
    Portable Utility water transfer pump works great 115V | eBay
    aram, here's the problem with that pump. the rubber impeller will get eaten up pretty quick, the noise it makes will deafen you, and the duty cycle is poor. plus it only has 3/8'' ips water ways. pretty slow.
    if you want to try 1, i have 3 in stock.
  • Bogart
    I just use a hole saw.
  • idlplumb
  • pipe doc
    i have the liberty pump also. use it for glycol (400 gal on one boiler job) & to empty w/h . great little pump.
