Wye strainer on new RPZ
  • Wye strainer on new RPZ
    Hey all, I am getting to replace an existing 3/4"RPZ. The existing has a wye strainer. The one I just bought doesn't come with one. Should I :
    1. Replace the rpz with a new wye strainer
    2. Try re using the existing wye strainer.(not really what I want to do)
    3.Forget the wye strainer all together
    Not really sure if a wye strainer is even required...Thanks , Oldie
    Re: Wye strainer on new RPZ
    the strainer is going to help protect the seals on the backflow from getting embedded with dirt particles. 1 thing you can do is check the old strainer and see what it has trapped. if it's empty, then chances are it's not doing anything. if it's full, you need to install a strainer to protect the backflow.
    they don't typically come with any protection from grit. while pressure regulators typically do.
      Gotcha , Thanks again
        Here in Illinois the wye strainer is code on all backflow devices except on a fire sprinkler system.
